Old 10-11-2003, 03:53 PM   #1
einherjar
einherjar is an unknown quantity at this point
My clutch plates are gone, aren't they.
hello,
i just want to confirm this before i get a new clutch kit.
within the last 2days my clutch feel has change drastically, last night my car felt like it was taking a little more time to catch / engage, but still was moving. this morning it was the same but i noticed that even if i was driving a constant speed if i step on it, my turbo would spool but my car would take about 2 seconds later before it would start accelerating. right now it is alittle worse it takes a long time and high revs to get the gears to engage.
this morning i lowered my clutch point hoping that was the problem, but it was not, i checked out my slave cylinder and it was snapping back no problem.
now if my clutch is gone, i need to get home on monday so i can deal with it, but i'm with family till monday (canadian thanksgiving) so is there any way i can drive it 1 hr. back home on monday? i do have 2 days to do stuff.
please help me out
thanks
`nik
btw, i did search and could not find anyone with similar enough symptoms that was not solved doing the trouble shotinning i did.
einherjar is offline   Reply With Quote
Old 10-11-2003, 08:30 PM   #2
S14lover
S14lover's Avatar
S14lover is an unknown quantity at this point
get a new clutch man sounds like the organic material is about to be gone trust me i know. 1hr souldn't be bad if your good to it on the way home.but that is just my opinion
She ****ing hates me ....TRUST!
S14lover is offline   Reply With Quote
Old 10-12-2003, 08:09 AM   #3
einherjar
well before i do that, can i just replace the clutch disc, without doing the whole kit? its from a recently installed sr20det, the pressure plate might be good.
because i can't find a clutch kit today i'm sure a disc would be much easier.
Old 10-12-2003, 09:39 AM   #4
240_keyy
240_keyy's Avatar
240_keyy is an unknown quantity at this point
Send a message via ICQ to 240_keyy Send a message via AIM to 240_keyy Send a message via Yahoo to 240_keyy
if you want my honest opinion, I have a suggestion for you. Order a 6-Puck ACT unsprung disk from Phase 2 or heavy throttle ($100 shipped) and then go to a parts store (Oreillies, NAPA, Advanced Auto) and order a remanufactured Maxima pressure plate ($40 to $60) and a TOB from a '95 240 (with the carrier if possible - $45) and you will be good to go with a bishin clutch setup that is grabby AND streetable for around $200 total. I have the setup described above in my car and it is AMAZINGLY good, so far it has about 65 hard clutch drops and it is still perfect.
There *is* a spoon...
240_keyy is offline   Reply With Quote
Old 10-12-2003, 09:45 AM   #5
russian
russian's Avatar
russian is an unknown quantity at this point
Send a message via AIM to russian
i have the same problem you do. u not alone dude
I must break you.
russian is offline   Reply With Quote
Old 10-12-2003, 10:32 AM   #6
einherjar
i think i will do that, its a good idea, do you think that maybe the sr pressure plate is in good condition? or a reman. maxima one would be in better condition. thank you
and russian, what do you plan on doing?
Old 10-12-2003, 10:37 AM   #7
240_keyy
240_keyy's Avatar
your SR one is *probably* good enough, but I noticed a good difference in pedal feel when I put the new pressure plate in. It is so cheap, it doesn't really matter
Old 10-12-2003, 10:40 AM   #8
russian
russian's Avatar
act hdmm clutch. fidanza flywheel, and b&m shifter. everything at the same time just more convinient.
I must break you.
Old 10-13-2003, 09:10 PM   #9
einherjar
sounds good
Old 10-13-2003, 10:34 PM   #10
joel
joel is an unknown quantity at this point
Send a message via AIM to joel
i searched both places and didnt find this supposed 100 clutch plate. where is it at? maybe a link or something
joel wikle
joel is offline   Reply With Quote
Old 10-14-2003, 03:40 PM   #11
240_keyy
240_keyy's Avatar
joel, you have to call or e-mail them and ask for just the disk.
Old 10-14-2003, 08:16 PM   #12
einherjar
i found one for that price
240_Keyy i pm'd you
