![]() Join Date: Jan 2003
![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Viper 5901 into s14. Help needed.
I am trying to install my Viper 5901 into my 97 240sx. I am still unsure about a few of the connections, even after searching1995-97 Nissan 240 SX Alarm, Remote Starter, Keyless Entry Wiring Information, Stealth Car Alarm Install - 95-98 Nissan 240SX, http://zilvia.net/f/chat/142355-inst...1xv-alarm.html. Any help would be appreciated.
Here are the connections I already know: H1 Main Harness H1/1 Red/White (-) 200mA Aux/Trunk output --> to trunk selonoid relay H1/2 Red (+) 12V constant input--> to 12V white in ING harness H1/3 Brown (+) Siren Output--> to sirens H1/4 White/Brown Parking Light Isolation wire--> not used H1/5 Black (-) Chassis Ground--> to ground H1/6 Violet (+) Door Trigger Input--> not used H1/7 Blue (-) Trunk Pin/Instant Trigger Input--> to tilt sensor, backup battery, and trunk light H1/8 Green (-) Door Trigger Input--> to red/white drivers side kick panel H1/9 Black/White (-) 200mA Dome Light Supervision output--> not used H1/10 White/Blue (-) Remote Start/Turbo Timer Activation--> not used, have an Apexi turbo timer (using diode) H1/11 White Parking Light output--> to red/blue ING harness H1/12 Orange (-) 500mA Ground when armed output --> to 507M tilt sensor and for fuel cut trigger The following harnesses have connections that I am unsure about. ![]() H2 Harness H2/1 Light Green/black (-) 200mA alarm disarm output --> to green/yellow, anti-theft H2/2 Orange/Black (-) 200mA Aux 4 output --> not used??? H2/3 Green/White (-) 200mA alarm arm output --> light green/red, anti-theft H2/4 Violet/black (-) 200mA Aux 2 output --> not used??? H2/5 White/Black (-) 200mA Aux 3 output --> not used??? H2/6 White/violet (-) 200mA Aux 1 output --> not used??? H2/7 Grey/black (-) Diesel wait to start input --> not used??? H2/8 Brown/black (-) 200mA Horn Honk output-->to yellow/green anti-theft module H2/9 Violet/White Tachometer input --> to yellow/red, ECM passenger side kick panel H2/10 Dark blue (-) 200mA status output -->not used??? H2/11 pink/white (-) 200mA flex relay control output -->??? H2/12 orange (-) 200mA accessory output --> ??? H2/13 purple (-) 200mA starter output --> ??? H2/14 pink (-) 200mA ignition 1 output --> ??? H2/15 grey (-) Hood pin input --> to yellow/black, anti-theft module H2/16 blue/white (-) 200mA 2nd status/rear defogger output --> ???? H2/17 brown (+) brake shutdown input --> to red/green , brake switch H2/18 black/white (-) neutral safety input --> ??????? H3 Remote Start Harness H3/1 Pink (+) Ignition 1 input/output --> to white, ignition harness car side H3/2 Red/White (87) Flex Relay input (30A Fused) --> not used H3/3 Orange (+) Accessory output --> not used??? H3/4 Violet (+) Starter output car side --> to black/yellow, ignition harness car side H3/5 Green (+) Starter input key side --> to black/yellow, ignition harness key side H3/6 Red Ignition 1 input (30A fused) --> to white, ignition harness key side H3/7 Pink/White (30) Flex Relay output --> ????? H3/8 Pink/black (87a) Flex relay input --> ????? H3/9 Red/black accessory/starter relay input (30A fused) --> ????? If someone could help fill in the question marks and correct any mistakes that would be greatly appreciated. Thanks Last edited by mikeroy420; 05-09-2011 at 06:33 PM.. |
![]() Join Date: Oct 2006
Trader Rating: (163)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 163 reviews
H1 Main Harness
H1/1 Red/White (-) 200mA Aux/Trunk output --> to trunk selonoid relay NOT USED H1/2 Red (+) 12V constant input--> to 12V white in ING harness CORRECT H1/3 Brown (+) Siren Output--> to sirens TO RED WIRE OF SIREN H1/4 White/Brown Parking Light Isolation wire--> not used CORRECT H1/5 Black (-) Chassis Ground--> to ground CORRECT H1/6 Violet (+) Door Trigger Input--> not used CORRECT H1/7 Blue (-) Trunk Pin/Instant Trigger Input--> to tilt sensor, backup battery, and trunk light CORRECT H1/8 Green (-) Door Trigger Input--> to red/white drivers side kick panel CORRECT H1/9 Black/White (-) 200mA Dome Light Supervision output--> not used OPTIONAL H1/10 White/Blue (-) Remote Start/Turbo Timer Activation--> not used, have an Apexi turbo timer (using diode) H1/11 White Parking Light output--> to red/blue ING harness CORRECT (set fuse for "+" under door on module) H1/12 Orange (-) 500mA Ground when armed output --> to 507M tilt sensor and for fuel cut trigger CORRECT The following harnesses have connections that I am unsure about. H2 Harness H2/1 Light Green/black (-) 200mA alarm disarm output --> to green/yellow, anti-theft CORRECT H2/2 Orange/Black (-) 200mA Aux 4 output --> not used??? CORRECT H2/3 Green/White (-) 200mA alarm arm output --> light green/red, anti-theft CORRECT H2/4 Violet/black (-) 200mA Aux 2 output --> not used??? CORRECT H2/5 White/Black (-) 200mA Aux 3 output --> not used??? CORRECT H2/6 White/violet (-) 200mA Aux 1 output --> not used??? CORRECT H2/7 Grey/black (-) Diesel wait to start input --> not used??? CORRECT H2/8 Brown/black (-) 200mA Horn Honk output-->to yellow/green anti-theft module CORRECT or optional H2/9 Violet/White Tachometer input --> to yellow/red, ECM passenger side kick panel CORRECT(or any fuel injector wire that is not the common color) H2/10 Dark blue (-) 200mA status output -->not used??? CORRECT H2/11 pink/white (-) 200mA flex relay control output --> NOT USED H2/12 orange (-) 200mA accessory output --> ??? NOT USED H2/13 purple (-) 200mA starter output --> ??? wire to pin 85 of a SPDT relay, Pin 87: heavy gauge 12volts from White wire in ignition harness, pin 86: small gauge 12 volt jumper from pin 87, pin30: heavy gauge wire to black/white in ignition harness, pin 87a not used. H2/14 pink (-) 200mA ignition 1 output --> ??? NOT USED H2/15 grey (-) Hood pin input --> to yellow/black, anti-theft module CORRECT H2/16 blue/white (-) 200mA 2nd status/rear defogger output --> ???? NOT USED H2/17 brown (+) brake shutdown input --> to red/green , brake switch CORRECT H2/18 black/white (-) neutral safety input --> If manual trans then e-brake wire at e-brake. If auto then ground it. H3 Remote Start Harness H3/1 Pink (+) Ignition 1 input/output --> to white, ignition harness car side BLACK/RED at ignition harness H3/2 Red/White (87) Flex Relay input (30A Fused) --> not used WHITE at ignition harness (the one that test as 12volt constant) H3/3 Orange (+) Accessory output --> not used??? CORRECT H3/4 Violet (+) Starter output car side --> to black/yellow, ignition harness car side CORRECT H3/5 Green (+) Starter input key side --> to black/yellow, ignition harness key side CORRECT H3/6 Red Ignition 1 input (30A fused) --> to white, ignition harness key side WHITE at ignition harness (the one that test as 12volt constant) H3/7 Pink/White (30) Flex Relay output --> ????? Cut the non constant 12v WHITE wire at ignition harness, this goes to NON key side H3/8 Pink/black (87a) Flex relay input --> ????? Cut the non constant 12v WHITE wire at ignition harness, this goes to key side H3/9 Red/black accessory/starter relay input (30A fused) --> ????? WHITE at ignition harness (the one that test as 12volt constant) NOTE: You must set Menu 3, item 8 to option 2. This will set the Flex Relay for Accessory2 Last edited by Broadfield; 09-28-2011 at 10:09 PM.. |
#4 | |
Toby |
#7 |
Green - Power Lock ---> Lt. green/white @ anti-theft module (The anti-theft module is located just above hood release cable in the drivers kick panel.)
Blue - Power Unlock ---> Brown @ anti-theft module (The anti-theft module is located just above hood release cable in the drivers kick panel.) |
#8 |
![]() Join Date: Feb 2010
thank you so much, last question i hope. On Harness 2/3 i dont have a light green/red wire. i have a base 95 S14. what other wire can i use? i have a light green/ white
#9 | |
#11 |
Toby,
I am having some issues with the H3 harness install. My car is totally dismantled so I have no way of measuring 12V. I'm sort of confused on the flex relay wiring for the alarm and the white wire for the car. Do I tie the red/white, red/black, and the solid red together and solder that to the fuse side of the white wire? Do the pink/black and the pink/white get attached together and soldered to the white wire on the key side? Above it says that the pink/black and the pink/white wires are both 12V non constant, but the pink/white is on the car side and the pink/black is on the key side, this is confusing me, maybe it would be easier if I had a 12V supply, but some help would be greatly appreciated. Thanks |
#12 |
I think you are over thinking it. All of the heavy gauge red wires, whether they have a stripe or not, get tied into 12volts constant. The smaller red wire from the H1 harness also gets tied in with these wires. So I strip back all four wires and wrap them around the vehicles constant wire in the ignition harness and then solder/tape it. The vehicles constant wire is the white wire in the ignition harness. You will obviously need to test for this since there are two white wires in the ignition harness.
As for the accessory wire, which is the other white wire in the ignition harness, it needs to be isolated from the key cylinder during remote start. So in other words, the key cylinder cannot see 12volts on this white wire during remote start. So we need to cut it and loop it through the Flex Relay in the Viper. The in and out on the Viper is the pink/black and pink/white. So you need to cut this white accessory wire in half. On the side that goes to the key cylinder you will wire in the pink/black. Then the other side of the cut wire will wire to the pink/white wire. You will then need to make sure you read my programming note in my 1st post. |
#13 |
I have another question. My alarm chirps but the door locks don't open or close when I arm or disarm the alarm , also do my lights have to flash when I arm the alarm ? Or is it a mode that I have to select ?
Also pm me your paypal so I can send u for some beer . Thanks
#14 |
Haha, beer money. I will have to chip in too.
Yeah Toby, when it comes to wiring, I always over think things. I dont know how people do this for a living. Upside down, head in the dash. My neck and back are sore. I didnt see the second white wire, that were my confusion was. Thanks again. I have a friend interested in some audio gear. I was wondering if you could pm me with some prices for your top of the line 6x9's and 6 or 6 1/2 speakers. And a top of the line amp to run 4 of those speakers. Please and thanks. |
#15 | ||
Yes, they have to flash if you have the parking lights hooked up. May I ask why you don't want them to flash only on arm? You may be able to use a relay to interrupt the parking light feed from the Viper. You would trigger it with the green lock wire from the Viper. You won't know until you trying it though... the timing is going to be close. LOL, thanks for the offer.... but I don't drink beer anyway. ![]() Quote:
As for the audio equipment, are you sure he wants pricing on my top-of-the-line stuff? That gets out of hand real quick. I'll send you a PM and we can discuss it. |
#16 | |
The question about the parking lights is that mine don't flash , so I'm thinking I hooked something up incorrectly . I do want them to flash when arm and disarm. I just hope I don't have a bad system. Sent from my iPhone using Tapatalk !
#17 |
Toby, with the audio sensor and its extra 3 pin connector. I dont have a shock sensor, so can I just use the prox/motion sensor in its place? Thanks
#18 | |
As for the parking lights, do you have the correct red/blue wire.... did you test to confirm? There are two red/blues in the ignition harness if that's where you got it. Only one of those is the parking light wire. Also, the obvious: did you insert the parking light fuse under the door on the brain? Basically the prox will plug into the port on the brain. Then you will cut off the ends of the audio sensor and tap the blue, red and black wires in with the same colors on the prox cable. Does that make sense? |
#19 |
Got it. Thanks again
If I was to use the the dome light supervision output, how would go about doing that? Connect the alarms green and black/white together. Connect them to the red/white in the dirver's side kick panel and ground the alarms violet? Last edited by mikeroy420; 05-16-2011 at 05:07 AM.. |
#20 | |
Relay: 85 --> Black/white 86 --> 12 volts constant 87 --> Ground 30 --> Vehicle's door trigger(so just tie it in with the green wire on the Viper) |
#21 | ||
#22 |
So with the blue and green wires disconnected from your OEM door lock wires, if you touch the green wire to the OEM lock wire it locks the doors? Likewise if you touch the blue wire to the OEM unlock wire it unlocks the doors? If so you have a bad system. Unless you have a bad ground for the Viper. But I assume it's ok since you said the rest of the Viper works.... correct?
#23 | |
Thanks, Rafael. Sent from my iPhone using Tapatalk !
#25 | |
H1/7 Blue connects to red at the anti-theft. Mine has been moved from pin 26 on the anti-theft to pin 20 on the A/T Countrol Unit. It must have been done by the previous owner. Can I still use this? |
#26 | |
As for the red wire, this is your trunk pin trigger. So you need to test it to be sure. With the trunk closed, the red wire should rest at 12V+ or open. When you open the trunk the red wire should go to ground. |
#27 |
I am trying to wire up two relays off of negative triggers for the trunk popper and the fuel cut. I was just wondering if you could confirm this wiring is correct.
Truck Popper Relay 85- Red/White from alarm (-) 86- 12V from Battery (fused) 30- 12V from battery (fused) 87a- not connected 87- to truck solenoid Fuel Cut 85- orange wire from alarm 86- black/red ignition at key switch 87a- black/yellow at fuel pump relay or pump 87- not connected 30- 12V fused from battery |
#28 |
I dont know if its were everything is disconnected, but my red wire is a short to ground. So I dont know if there is a switch in the AT control unit the switches the voltage.
Pin 20 on the AT control module is the selector for ''R" for the automatic transmission. |
#29 | |
#30 |
Toby,
I am unable to find the red wire for the trunk trigger. Is there an alternative? I am also unable to locate the light green/red wire on the anti theft module. I am assuming that the anti theft module and the SECU are the same thing, is this correct? If so, mine doesnt have all the pins. Looking at the fsm and the pin out, I believe the the light green/red wire should be pin 8. But on my connecter only has one pin on the bottom, pin 10 brown. I'm really confused now. The person that owned the car before me must have been at the harness, I'm finding splices and tape everywhere. |
