Old 05-09-2011, 08:08 PM   #1
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
// SR20DET Parts Galore - LOOK Inside//
Email > [email protected] < Paypal send payment as a personal gift or pay the 3% fee - add in note what your paying for as well as your shipping address.
Concord, NC 28205
Email/PM me offers or to get shipping quotes / I need your City/State/Zip
All prices do not include shipping
__________________________________________________ ____________________________________________
FS: SR20 JE 87mm / 3.425in .040 over stock (86mm / 3.386in) - 8.5:1 CP Pistons
FYI Stock SR20 pistons are - 86mm / 3.386in with a 8.5:1 CP
Will work on any SR20
Used but in perfect working condition
Rings are in good shape but will need to be file fit to your block a new set can be had for $100 or less - if needed
1 piston has been banged around but nothing affects its performance
Another piston has a few scars on the skirt but again will not affect the performance
The carbon build up (not bad at all) will clean right off with whatever way you use - if you dont know any ways to remove it google search there are tons of ways to do it - I just have not had time to clean them.
These are $600.00+ new
$350.00
Download the Piston spec sheet: http://www.jepistons.com/PDFs/TechCorner/S..._instrc4032.pdf
In case you cant read the micrometer - in the first pic - it reads 3.4245 - all pistons are in the range of 3.4245 - 3.425 - this is measuring from bottom of skirt up 1/2in in an 80deg. garage
SR20DET Greddy Oil Pan
Painted black - can be removed easily
1 long and 1 short bolt is missing - $.50 @ hardware store
Each baffle is missing a screw as they dont line up - but they are secure and not going anywhere
Used on a rebuild that made it to idle and then the whole project was parted out.
I was going to use it on my project SR but need $ of other things
$285.00
SR20DET Redtop Valve Cover
Normal wear and tear - nothing major - great for a core on powder coating or use it as-is.
No hardware - valve cover only.
$75.00
If you want a coil pack cover add $25.00
FS SR20DET GREDDY / TRUST / GREX METAL HEAD GASKET
Brand New in Box
I was going to use it on m SR build but need the money for more important things
Part # 13521183
88 1.4mm
This will work on any bore size 88mm and smaller
FYI - Stock SR - Bore & Stroke 86mm x 86mm
$265.00 new from Greddy
http://www.greddy.com/products/engine/meta...er:make:Nissan/
GReddy
$215.00
SR20DET Front timing cover with oil pump
$70.00
SR20DET Bottom mount turbo manifold - turbo mounting stud will need to be replaced
$70.00
SR20DET Ignitor - came off a redtop harness
$55.00
SR20DET Coil pack harness - came off a redtop
$45.00
SR20DET tranny to motor dust plate
$45.00
SR20DET Flywheel - off a redtop needs resurface
$25.00 or $75.00 resurfaced
SR20DET RWD ARP Head Studs
1 torque cycle
$90.00
S13 Redtop SR20DET A/C Bracket
$45.00
S13 SR20DET Fuel Rail w/ caps - no injectors or FPR
$30.00
S13 SR20DET T25 Turbo Lines
$10.00 each or both for $15.00
S13 SR20DET Alternator Bracket - No tensioner bolt/nut
$30.00
SR20DET Brand New Clutch Bolts
$30.00
S13 SR20DET Throttle Bodies with Auto TPS
$25.00
SR20DET Stock Crank, P/S, Alt. Pullies
Crank has small chip on A/C side - Hurts nothing - Only cosmetic
$50.00
S13 SR20DET Intake Manifold (Bare)
$30.00
JDS Performance is offline
