Old 05-16-2011, 05:10 PM   #1
turbo-travis
turbo-travis is an unknown quantity at this point
S13 zenki vs. Chuki headlights Identical?
I just bought another S13. It has some damage to the headlight/fender so I need to replace both. I got a headlight assemble from an 89 hatch to put on my 91 coupe. Im have a tight fit near the hood and fender, although it will fit and clear the hood when popping up. I can adjust the hood for a little bit of clearence but I was wanting to make sure the headlights are exactly identical between the zenki's and chuki's. It seems like there is more of a gap between the headlight and bumper. If they are the same then as suspected my front support may be bent a bit. Here's some pics to compare the good left side to the snug right side. BTW i know the gap against the fender is huge because of the damage to the fender, just worrying about the hood to headlight, and headlight to bumper clearence
turbo-travis is offline   Reply With Quote
Old 05-16-2011, 05:26 PM   #2
!Zar!
!Zar!'s Avatar
They are the same. I believe there is some wiggle room for the cover its self, but it looks like your fender is what is misaligned.
Old 05-16-2011, 05:43 PM   #3
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
I agree with Zar. Fender is what's throwing it off a bit.
The other piece that may be bent (which is creating the gap between the headlight and the bumper) is the bumper bracket.
Bottom right corner, the second one.
-Jspec-
Instagram/CrimsonRockett
Old 05-16-2011, 05:59 PM   #4
turbo-travis
hmmm, okay i have the plastic piece for the headlight, havnt installed it yet. I'll do that with a new fender and see how the clearence looks
Old 05-16-2011, 06:07 PM   #5
!Zar!
!Zar!'s Avatar
You can adjust the fender slightly.
Try loosening the bolts that hold the fender down and try pushing the fender inward and then tighten down the bolts.
Old 05-16-2011, 06:09 PM   #6
turbo-travis
well the fender is worse than what it looks in the pics so i'm just gonna replace it. I'll adjust accordingly though on install
