Old 05-18-2011, 01:30 PM   #1
TFD
TFD is an unknown quantity at this point
SR SR20 f*cked after compression test? Please check with me
Long story short:
After last weekends dragevent the car gave some white smoke when hitting gas or letting go. Sparkplugs are white btw with black innercore.
So drove around the block tonight and did compressiontest:
- warm up
- disconnect fuelpump
- take plugs out
- open throttle
etc.
50/52/42/50 psi.....
after the oilspoon I've got 156/160/90/158 across.
Ok, fine. #3 is bad. Build stuff back together and started to get the oil out... white smoke..... more white smoke... entire block is white now and the car wants to stall. Vacuum is dropping off.
My conclusion: bad pistonrings and a blown headgasket?
Please guys, let me know what you think before i pull the engine out.
Thanx,
Daniel
Edit: Coolant looks murcy with brownish sealant in the expansionreservoir => blown headgasket.
JDMstyle-Driftstyle-Dish-Stickerbomb-Stretch-Bye Bye Kitty...
TFD is offline   Reply With Quote
Old 05-18-2011, 01:39 PM   #2
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
sounds like a strong possibility.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 05-18-2011, 01:48 PM   #3
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
Sounds like a HG, but drop the oil pan and see if you can see any shavings
JohnnyDrfiter22 is offline   Reply With Quote
Old 05-18-2011, 01:50 PM   #4
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
just do a leak down test.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 05-18-2011, 10:21 PM   #5
95zenkisr20
95zenkisr20 is an unknown quantity at this point
I hear you man i had the exact same thing happen to me .... 3 times in a row... Basically its a blown head gasket maybe you over heated the block or pushed to much boost on a stock tune and POP goes the head gasket..... Heres what i did to finally get it running perfect
- first did a compression test.
- then did a leak down test.
- found out that it was a blown head gasket. ( but could also be bad rings)
- take motor to machine shop have them check.
- new rings, resurface block and head, have them check to see if its warped
- arp head studs and cometic head gasket
- make sure everything is torqued down correctly
- and make sure there are no air bubbles in the coolant lines
thats just my experience hope could be of some help
95zenkisr20 is offline   Reply With Quote
Old 05-18-2011, 10:40 PM   #6
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
according to your post... all the cylinders are fuked..
" 50/52/42/50 Dry?
156/160/90/158 wet?
Chrischeezer is offline   Reply With Quote
Old 05-18-2011, 10:43 PM   #7
95zenkisr20
thats kinda how my experience was except i didnt have that big of psi jumps from being dry to wet like 60 psi jumps
Old 05-19-2011, 12:53 AM   #8
TFD
@95Zenki: Your list is exactly my idea of things to do. Will take the engine out this weekend.
@Chris: Yep, sounds like it haha. New rings are gonna be in when stuff is apart, so should do the job icw new headgasket.
Old 05-25-2011, 03:25 PM   #9
TFD
Update:
Did another compression test to rule out a faulty gauge and this time the numbers were all around 90 psi... checked my neighbours fresly rebuild engine with known 150psi comp and the gauge read another 93 psi....
Not the best measurements but a good indication bottom end seems to be ok.
Took the engine apart and found out
- Oil + coolant on all 4 cilinders/exhaust ports
- Headgasket looks fine
- Pistons look fine, no damage
- Rings are there (feeler-tested around piston)
- Walls are perfect
I think i lifted my head?!
What else could pour oil and coolant into ALL cilinders?
Ideas are appreciated guys
Daniel
Old 05-25-2011, 03:50 PM   #10
95zenkisr20
hmmm how much boost running?
Old 05-25-2011, 03:52 PM   #11
TFD
1.3/1.4ish bar = 21 psi on a warm day...
This is all on an unopend stock block (as far as I know, since two small outher headbolts were missing when taking the head off, OEM hg inside).
Old 05-25-2011, 03:53 PM   #12
95zenkisr20
stock tune im guessing?
Old 05-25-2011, 03:57 PM   #13
TFD
JWT ecu tuned for all the boltons.
How hard is it to unbolt the headstuds? Got myself the 10mm torq with a 2 ft. piece of pipe and some decent force and the studs allready squeled.
Can remember it took severe more power/PITA last time i took them out of a Primera engine...
Old 05-25-2011, 04:04 PM   #14
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
21 psi on stock turbo with stock HG and bolt ons.
You fucking joking? How long were you able to run this?
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 05-25-2011, 04:06 PM   #15
TFD
21 psi on
stock block
2871 .86
z32 maf
nismo 740cc
JWT ecu etc. etc.
Sorry, my bad.
Old 05-25-2011, 04:10 PM   #16
KaminaSan
KaminaSan's Avatar
Originally Posted by TFD View Post
21 psi on
stock block
2871 .86
z32 maf
nismo 740cc
JWT ecu etc. etc.
Sorry, my bad.
That's still a very large amount of boost for stock headbolts and headgasket.
I'd say get your head decked. Get a cosworth headgasket, and some arp headstuds, slap that shit on, and call it a day.
Old 05-25-2011, 04:14 PM   #17
TFD
Thats exactly the plan if im sure the head lifted and nothing else is f'cked.
Thanx for your support guys.
Old 05-25-2011, 04:16 PM   #18
cotbu
cotbu's Avatar
I think the head lifted as well. White engine indicator.
Thats probably the good news.
Sent from my highly tuned vibrant!
Old 05-25-2011, 04:16 PM   #19
KaminaSan
KaminaSan's Avatar
True true, but just think about it, if you have the funds, now would be a perfect time to upgrade the head a little bit. Springs/retainers, RAS. Shouldn't be too expensive.
Old 05-25-2011, 04:19 PM   #20
TFD
Jup, i know. Especially when you know I've putted TODA cams in last month so I didnt have to take off the head for new valves and springs haha... (considering the HKS step 2's).
