Old 05-30-2011, 12:22 AM   #1
mrrisk
mrrisk's Avatar
mrrisk is an unknown quantity at this point
FS/FT Socal Celica tacoma swapped slammed kitted caged $3900
currently non-op'd
Located in SoCal OC
714 854 4078
Here are the specs on the car and extras im including.
the sideskirts/ rear bumper valence are custom "one-off" they only exist on this car.
1980 Toyota Celica
Engine
- mid '90s Toyota Tacoma 2RZFE 2.4, runs strong!
- Injen intake
- generic greddy air filter
- oil filter relocation kit
- jba? headers
- voltmeter, water temp, oil pressure
- all steel braided with AN fitting fuel setup
- 1.5 liter surge tank from Speed Machine performance
- 255 lph Walbro fuel pump
- NGK plug wires and plugs
- 2.25 exh. piping to Bosal/ Brospeed muffler with resonator, No Cat.
- Setrab oil cooler with AN fittings/ steel braided lines
Drivetrain
- 6 puck EZ clutch
- short shifter
- W58 trans. off '85 Celica w/ W59 tacoma bellhousing bought new from Cabe Toyota
- BAKER steel braided clutch line
- '81 Toyota Supra rear end with disc brakes( car originally had rear drum brakes)
- welded diff.
Suspension
- KYB adjustable short stroke shocks
- Tarmac NCRCA's
- ae86 TEIN camber plates
- 9kg front springs
- ae86 Megan Racing tension rods
- ae86 Megan Racing rear 4 links
- Energy Suspension bushings on rear lat. bar, front/ rear swaybar endlinks, and lower arms
- ae86 Tanabe front/ rear sway bars
- ae86 rear 7kg Swift springs
Steering
- 2rz tacoma p/s pump
- '81 Celica p/s steering box
- custom steel braided p/s lines
- Ford T-Bird p/s Cooler
- steering angle mod
Brakes
- ae86 front brakes, cross drilled/ slotted rotors
- rear stock supra rotors/ calipers
- BAKER steel braided brake lines front/ rear
Interior
- 6 pt cage
- driver/passenger '84 supra seat
- Grant/ Mooneyes blue metal flake steering wheel w/ hub adapter
- Autometer 3" tach with shift light and MSD rpm activated switch wired into shift light
Stereo
- Pioneer cd player
- front Pioneer 4x6 speakers
- rear Pioneer 6x8 speakers
Exterior
- custom cowl hood, also got extra hood with a drop vent in it and another with a hood scoop over where stock carb would be on a 20R/22R
- JDM hood emblem
- JDM fender mirrors
- nissan maxima headlight conversion
- urethane 280xz front lip modded, also have the modded ae86 N2 lip im including
- knockoff modded S14 BN Sports sideskirts
- S13 URAS style rear bumper/ valence
- ae86 TRD style rear spoiler
- Mooneye's "Hot Rod" emblem on grille
- Flat White
Wheels
- currently sitting on a set of spaced out 14x7 supras
$3900 or trade
Miata, S14, GC8, show me what you have
mrrisk is offline
