![]() Join Date: Feb 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
![]() I have spent the past two days searching out my wiring harness and this is what I have come up with, please correct me if you can
main concern is with door locks ive researched and found and answer but dont understand why I am grounding h2/1,4... What are some examples of using this flex relay? main harness H1 h1/1 red/white - trunk = Not USED? h1/2 red +12vdc constant = White (which one?) h1/3 brown + siren = siren feed h1/4 white/brown pk light iso = NOT USED? h1/5 black ground = ground h1/6 violet + door trigger = NOT USED h1/7 blue trunk pin = RED h1/8 green - door trigger input = RED/White h1/9 black/white FLEX RELAY ??? do I need if not Remote starting? h1/10 white/blue - 200ma aux 1 =Not used h1/11 white parking light output =Red blue Door lock harness H2 h2/1 violet = TO GROUND? h2/2 Blu/Blk = unlock trigger circuit BROWN - ? h2/3 Brwn/Blk = not used? h2/4 violet/blk = TO GROUND? h2/5 grn/blk = - dr lock trigger = light blue/ white h2/6 white/blk = NOT USED? h2/7 h2/8 flex but what is used for? windows? *** My SE did not come with security module, will these wires still be in the harness in that location? also do I need to connect the door trigger pin to the pass side so it sees both doors? **** h3/3 green/ black starter norm closed motor sided, dont need right? last question if I buy an avital 4003l for remote start, what would change in the wiring diagram I am not a complete moron but the last viper I installed was in the late 1990's and seemed to be a bit less confusing with external relays, I like that they are on board but the instructions are a bit lacking.... Can a window module be used with out bitwriter to activate the moon roof in both functions back or up?
Wanted: Good well mannered athletic woman with her own classic or sports car.... send photo of car |
