Old 06-06-2011, 07:16 AM   #1
s141996
s141996 is an unknown quantity at this point
Viberation at high speed!!!help
Well here is the problem I drive the car past 45mph and viberation starts the higher i speed the more it viberates its coming from the rear! any idea on what is going on???
s141996 is offline   Reply With Quote
Old 06-06-2011, 07:47 AM   #2
murda-c
murda-c's Avatar
most likely tires are flatspotted, a rim is bent, or tire is out of balance.
swap your rears for your fronts and see if the vibration follows.
Inspect the tires and wheels while you have them off.
Old 06-06-2011, 07:49 AM   #3
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
Have you checked your wheels to make sure they are seated, not warped, don't have a hub-centric ring behind them when they don't need it, the lug nuts are on the whole way and torqued.. I'd start there.
Side note I seen "Viberation at high speed!!!help" and though you were stuck under a fatty, lol
mattack69 is offline   Reply With Quote
Old 06-06-2011, 10:07 AM   #4
s141996
lol!!!!!!and i'll do that when i get home thanks guys!
Old 06-06-2011, 10:19 AM   #5
nismo 240sx
nismo 240sx's Avatar
nismo 240sx has a little shameless behavior in the past
worst case also check the weights that are on your drive shaft...
nismo 240sx is offline   Reply With Quote
Old 06-06-2011, 12:18 PM   #6
camaro379ss
camaro379ss's Avatar
camaro379ss is an unknown quantity at this point
most likely NOT an out of balance tire unless there's just absoluelty no weights on it whatsoever. An out of balance wheel will vibrate at a certain speed and go away at another.
Most likely causes as some have previously stated...
1. bent wheel
2. tires could have flat spots
3. Driveshaft imbalance
Most of these are quite easy to see visually.
1991 Nissan B13 Sentra sr20det 300whp/1991 Nissan S13 240sx sr20det ~260whp
camaro379ss is offline   Reply With Quote
Old 06-06-2011, 03:22 PM   #7
SR240Z
SR240Z's Avatar
SR240Z is an unknown quantity at this point
Bring it by the shop, we can check all that out for you.
Very likely to be one of the things listed by camaro379ss
2004 IS300 Sportcross 1JZ
SR240Z is offline   Reply With Quote
Old 06-06-2011, 03:30 PM   #8
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I bet its something interior related.
Old 06-06-2011, 04:45 PM   #9
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
are flat spotted tires fixable?
a good burn out?
surge s14 is offline   Reply With Quote
Old 06-06-2011, 05:12 PM   #10
camaro379ss
a good burn out?
generally no. Depends on how long they sit. Sometimes you can simply drive them out so to speak.
Old 06-15-2011, 12:46 AM   #11
KYjellaye
KYjellaye is an unknown quantity at this point
My car did the exact same thing. Once it got past 40mph it start have violent vibrations from the rear of the vehicle. It turned out that some of the bolts from the driveshaft to the diff were loose..
KYjellaye is offline   Reply With Quote
Old 01-08-2012, 11:32 AM   #12
RentonD
RentonD is an unknown quantity at this point
Hate to bump an old thread but thanks KYJellaye, you just saved me a ton of trouble.
RentonD is offline   Reply With Quote
