Old 10-27-2003, 06:07 PM   #1
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
messed up susp. probably bent frame
So after i installed my coilovers i drove the car for a couple days and then decided for sh!ts and giggles i'd measure from the center of each wheel to the top of the fender to check my ride hight. All came out fine except my driver-side rear wheel. It was 1/2 inch lower than the others respectively.
My car was hit on that corner earlier in its life. I inspected the subframe and it appears to be perfect. All suspension arms are the same length and none appera to be bent. so the only thing i can figure is that the frame was bent in the prior crash and they bolted on new stuff and left the frame somewhat bent and figured it was good enough.
I'm having the car put on a frame rack next week to see how bad it is and hopefully pulled.
Here are my questions:
Is it safe to just raise up that corner of the car via my coilovers if they can't fix the frame?
Is it safe/recommended to make some steel spacers to put inbetween the left side of the subframe only and frame then have the car corner balanced?
Neither of these ideas seem intuitively like good ideas to me but i just thought i'd throw it out there. I don't know why but they just don't seem like good ideas, but they ran through my head so i figured i'd ask.
Thanks to all who help in advance!!!
RBS14 is offline   Reply With Quote
Old 10-27-2003, 06:35 PM   #2
240Dave
240Dave's Avatar
240Dave is an unknown quantity at this point
I'd recommend recounting threads on your coilovers...
240Dave is offline   Reply With Quote
Old 10-27-2003, 06:46 PM   #3
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
different corners of your car have different weight so the suspension can sag more... i think the frame rack will show that your frame is straight.= and you can use the coilover adjustment to straighten it out....BTW how much does a frame rack inspection cost?
Var is offline   Reply With Quote
Old 10-27-2003, 06:50 PM   #4
RBS14
RBS14's Avatar
that'd be great if it was straight! free to see if anything is wrong and around $200 to fix anything that may be wrong.
240dave- you think i could be off by half an inch? everything was within 1/16th of an inch before i put it on the car.
Hopefully frame is straight or can be easily pulled and i can adjust the rest via coilovers.
Old 10-28-2003, 01:14 AM   #5
thx247
thx247 is an unknown quantity at this point
I just know its REALLY hard to find bent suspension parts while they are installed on a car. You have to measure parts like a mofo before you find whats bent.
thx247 is offline   Reply With Quote
