Old 06-13-2011, 11:45 PM   #1
chuki monsta s13
chuki monsta s13's Avatar
chuki monsta s13 is an unknown quantity at this point
Thumbs up PBM spacers 15mm vs rota p45r 17x9.5 +12
eyy zilvia, i was interested in purchasing 15mm pbm bolt on spacers to of course push my wheels out further... as you know every girl likes a lil poke anyways i read somewhere that pple having issues mounting them on cuz of the design of the p45rs or sumthin.. jus wanted to know if anyone can clear this up..
thanks, meaing you run spacers with p45r
OHHHH SHITTTT!!
chuki monsta s13 is offline   Reply With Quote
Old 06-13-2011, 11:50 PM   #2
KOME
KOME's Avatar
KOME is an unknown quantity at this point
I'll poke you if you can't solve your problem. I work for lunch, or a sandwich.
KOME is offline   Reply With Quote
Old 06-14-2011, 12:02 AM   #3
S14kouki_10
S14kouki_10's Avatar
S14kouki_10 is an unknown quantity at this point
yall aint poking
S14kouki_10 is offline   Reply With Quote
Old 06-14-2011, 10:13 AM   #4
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
I have 15mm spacers from PBM as shown here:
Don't most spacers look like this? Why wouldn't p45's fit for more poke...
EDIT: I think they wouldn't fit because of the excess from your old studs. P45's may not have holes to accommodate for it. 15mm doesn't cover the old studs up.
Here's a better pic but when you mount the spacers, you tighten nuts on the old lug mounts and there is still some excess left. One way to correct the excess is to cut/grind it off.
^And yes, I put the bolts on the wrong way. I realized that after I took the picture and proceeded to fix it
For Sale #1 | For Sale #2
Old 06-14-2011, 10:59 AM   #5
94_240sx
94_240sx is on a distinguished road
You should use hub centric spacer looking like this(see the middle ring that sticks out). It's important because your wheel will seating on hub. Bolts are there to secure the wheel on the hub.
courtesyparts.com
94_240sx is offline   Reply With Quote
Old 06-14-2011, 06:05 PM   #6
chuki monsta s13
Wink
i see, wat u did there, but the thing is i run extended studs up front ichiba to be exact.. and havve a set of nismo extended for the rears not installed yet.. 15mm spacers is only so much, so i understand your explanation of studs sticking out.. 25mm would not be an option, as in my opinion is too much poke but 20mm spacers i think would suffice
OHHHH SHITTTT!!
Old 06-14-2011, 06:09 PM   #7
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Some wheels do have enough hollow space where the studs protrude through, but a lot of wheels do not. It takes 25mm spacers just to clear OEM studs, and if you have extended studs, you would have to go even wider than that.
Old 06-14-2011, 06:58 PM   #8
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
^^^Co-signed. I had some 20mm & 30mm spacers laying around. Only the 30mm's cleared the OEM studs so that the wheel could sit flush. The 20mm spacers let too much material poke through to clear. But I wanna say it seemed like more than 5mm excess, more like 10mm.
I'm really surprised P45R's don't have that little hollowed out space for excess stud material.
simmode1 is offline   Reply With Quote
Old 06-14-2011, 06:59 PM   #9
Teddy
Teddy's Avatar
Trader Rating: (44)
Feedback Score: 44 reviews
I bet you know that from your Hanabi's
www.realize-jp.net
Old 06-14-2011, 07:45 PM   #10
chuki monsta s13
this is what i have but in white.. i notice they carry extra holes would that help me fit bolt on spacers less than 25mm bolt ons
/Users/mymac/Desktop/17x9.5-ROTA-P45R-WHEEL-RIMS-4X114.3-12MM-HYPER-BLACK-for-sale_370479850166.jpg
OHHHH SHITTTT!!
Old 06-14-2011, 07:58 PM   #11
ayuaddict
ayuaddict's Avatar
On my vehicle, I installed the spacers and cut the studs off so that they were flush with the "spacer lug nuts". Ran 15mm spacers with any wheel, no problem. Studs are like 89 cents each so if i every need to remove the spacer It'll cost me less than $10. And this was to clear my tie rods.
Old 06-14-2011, 10:01 PM   #12
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
What are those Nissan emblem shaped things on the spacer? First time I've ever seen and I used to have PBM spacers.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 06-14-2011, 10:04 PM   #13
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
^ I belive it is their new design to use a 15mm and use up to a 8mm slip on so it locks into place? correct me if i am wrong.
Dustxking is offline   Reply With Quote
Old 06-14-2011, 10:07 PM   #14
zooopreme
Trader Rating: (38)
that's the rear side of the spacers. That's the bottom part of the extended studs.
Old 06-14-2011, 10:08 PM   #15
wh0aitznic0
Wait, I feel retarded lol.
They're two spacers facing each other and that's the bottom. -___-
<3
Old 06-14-2011, 10:21 PM   #16
chuki monsta s13
back on topic pleeze
OHHHH SHITTTT!!
Old 06-14-2011, 10:28 PM   #17
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Looks like they have giant holes between where the wheel studs go through....that would leave me to believe they'd work with 15mm spacers.
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 06-14-2011, 11:57 PM   #18
chuki monsta s13
exactly wat i thought
OHHHH SHITTTT!!
Old 06-15-2011, 01:22 AM   #19
simmode1
simmode1's Avatar
Are you sure the other set of holes aren't for another lug pattern? Like 4x100 versus 4x114.3?
I assume we're talking about 4 lugs, because P45R's don't come in this size/offset for 5 lug anymore....
Old 06-15-2011, 04:42 AM   #20
nathanong87
nathanong87's Avatar
i'm 95% sure that p45 are not multiple lug pattern
natelife.tumblr.com
Old 06-15-2011, 04:45 AM   #21
ayuaddict
ayuaddict's Avatar
If I remember correctly, although the relief holes are not exactly 5x114.3, they are a large enough diameter to clear studs.
Old 06-15-2011, 06:16 AM   #22
sidewaysil80
sidewaysil80's Avatar
sidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to allsidewaysil80 is a name known to all
pretty sure pbm spacers are hubcentric. hubcentric is when the i.d. of the spacer is machined to fit snug on the hub. i think you're referring to wheel centric spacers or a ring that makes it fit snug on the i.d. of the wheel.
sidewaysil80 is offline   Reply With Quote
Old 06-18-2011, 03:39 PM   #23
chuki monsta s13
thanx erybody for input
OHHHH SHITTTT!!
Old 06-18-2011, 03:42 PM   #24
joel.e.krueger
joel.e.krueger is an unknown quantity at this point
they work.
boisedrift.com
joel.e.krueger is offline   Reply With Quote
Old 06-18-2011, 05:46 PM   #25
Bushido
Bushido's Avatar
p45's are only cast with one bolt pattern, the other four holes are fo dekrayshun
p45r, pbm, spacers
