180sx gets the shakes, and goes nowhere
Test drove another 180sx today and if you hold the revs at 3000-5000rpm and release the clutch, the car will just shake and and go nowhere
Had the exact same issue in my last 180 too so must be a common problem, could be plugs or coil packs or both? Has anyone had the problem and rectified it? Apart from that the car was pretty much straight as an arrow and appeared to be one of the lesser flogged 180s ive driven, so any ideas? ![]() |
#5 |
![]() Join Date: Oct 2008
check the ecu see if its throwing codes my ca was doing the same thing, check my coil packs and everything else. Ended up being the knock sensor went bad and pulled timing
![]() Last edited by bikerskater; 06-14-2011 at 11:58 AM.. Reason: typo |
#6 |
![]() Join Date: Dec 2006
literally go nowhere?
If so your clutch is fried and needs to be replaced. If it drives but has no power and sounds like a WRX then its either a Spark or Fuel injector problem
1989 Built SR GT2871R -363whp 1998 S14 W/RB25- 250ish (For Now) 1986 SR86 - 200ish 1990 R32 GTR - 320hp Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit |
#7 | |
How did you fix it? replaced knock sensor? |
#9 |
i did a bypass you use a 1m ohm resistor and wire it into the 23 pin on the ecu and ground it makes it think that the knock sensor is fine and then go from there if that works you can replace it or leave it
