Old 10-28-2003, 03:48 PM   #1
project_240
project_240 is an unknown quantity at this point
pls help me install a shift light
hey guys i have a 95 240sx and just got a shift light today. there are 3 wires coming out: red, black, green. black is obvious, you need to ground it. the red wire goes to power, but what im confused about is what power source should i connect it to? and directions say you need to find the tach terminal, and connect the green wire to it. so i now know what to connect the wires to, but where are these things?
-jake
project_240 is offline   Reply With Quote
Old 10-28-2003, 06:36 PM   #2
twitchy
twitchy's Avatar
twitchy is an unknown quantity at this point
why do you need a shift light if your car has a tach?
it probably goes to your tach wire
Who the hell needs a sig anyhow
twitchy is offline   Reply With Quote
Old 10-28-2003, 09:43 PM   #3
DudeYourSoOOJDM
DudeYourSoOOJDM's Avatar
DudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud ofDudeYourSoOOJDM has much to be proud of
Send a message via AIM to DudeYourSoOOJDM
red - power
green - signal
black - ground
The best place to get a signal would be on the wires on your cluster that are for the tach. Pull your cluster out and find them.
Why not just look at your tach......
If you have a tendency to "bounce" off the rev limiter, then this might be a good idea.......so would Rocker arm Stoppers if your SR...
Since 2001.
DudeYourSoOOJDM is offline   Reply With Quote
Old 10-28-2003, 11:20 PM   #4
twitchy
twitchy's Avatar
whats a rocker arm stopper?
Old 10-28-2003, 11:38 PM   #5
Fibercus
Fibercus is on a distinguished road
Send a message via AIM to Fibercus
If he tapped into the tach signal wouldnt his light be constantly flickering? I think hes looking for an adjustable signal.. which i think you have to make yourself
Say an RPM activated switch of some sort
Fibercus is offline   Reply With Quote
