![]() Join Date: Aug 2006
Fs: S14 for sale
Time has come to see what is out there. I really just need a trade and cash
I plan on moving in August and I need to have a car that has emissions With that said * THIS CAR HAS ZERO EMISSIONS* CONTACT: PM or email at [email protected] 167k on the body 45,000 kilometers on the motor Less than 2% on leak down. There is a build of my car online so you can see the progress it has made. 1995 Nissan 240sx Color: Concord Grey Small history of the car- When I first got it, the car had a KA24de in it. Stock front bumper all broken tabs on the headlights, s13 seats, generic wheel and shit. pulled the motor and got a sr20 from a friend out of his s13. The entire upper harness has been cleaned up and shortened, wrapped in that nice mesh and heat shrunk from a friend. It is also tucked under the intake manifold and Fixed some rust- Relocated the battery to the back. Didnt even have a ebrake lol There were so many things wrong with this car originally and had tons of missing bolts and random electrical issues. I decided to fix everything since I have owned it and really enjoy this car. MODIFICATION: PBM v3 RUCA, v2 Toe arms, and steering angle spacers, drain plug Stance GR+ Pro coilovers with 8/6 k springs New z32 inner tie rods, CS outters. New tie rod boots and a real alignment Tein Tension rods NEW: Energy suspension Subframe bushings and Power steering rack bushings z32 vlsd Extended front lugs 20mm spacers up front 15mm spacers in the rear Stock sr radiator with Dual Flex lite fans and shroud. (4)MB Battles 18x9.5 +15 purchased in October 2010 and brand new tires front and rear Apexi Safc Mines ECU z32 MAF RSR Downpipe w/ Welded bung AEM Wideband 02 sensor and gauge. Megan Short throw shifter. walbro 255 fuel pump Kouki S14 pass seat boost at 10psi z32 inner tie rods with new boots q45 Ignitor HKS ssqv 3in intake z32 30mm aluminum front and rear brakes ss brake lines FMIC/piping Bash bar jdm Navan front bumper HID's 6000k Nismo 270 sides and rear bumper Roof wing (cant remember what brand- was on bwags car) Nardi Steering wheel Momo Hub New shifter boot and bezel/ new Ac vents New drivers window switch NEW S14 oil pick up NEW Nissan water pump Non beat up door panels Autometer boost and oil pressure gauges Custom shift knob.Tomei replica. New r33 ebrake cables Kouki Tail lights OEM Rain guards Im pretty sure Im missing a ton of crap. pictures: ![]() ![]() ![]() coils when I put them on ![]() ![]() ![]() ![]() ![]() ![]() If anyone wants additional pictures or video let me know. 6800!!!! Im down with partial trades and cash. |
How bad of an emissions test do you need to pass? visual? sniffer? OBD scan?
http://zilvia.net/f/cars-sale/390890...osted-rwd.html I have a highflow cat, the car is reflashed so the emissions always reports it's ready if you OBD scan it, and if I take care of a few things it would have no CEL's and mostly functioning emissions. 800cc injectors, though, so cold starts are kind of gnarly... but I'd expect with a cat back in it it'd pass a sniffer test once it warmed up, and since the ECU's been fucked with it'll pass an OBD check no problem. Hell, I can take the car into school and put it on a sniffer to see where it's at right now... |
#5 |
Oh, by zero emissions you mean it hasn't passed?
I thought you jammed an electric motor in there somewhere! Sweet car, wish I lived closer, then I'd jump on this. |
#7 | |||
^ this guy is right. |
#9 | |
Unless someone can correct me I thought when they check cars for emissions if it doesnt look FACTORY it wont pass. Again, this is the ONLY reason why Im selling the car. Thank you for your interest! |
240sx, drift, sr20, turbo |
