Old 07-04-2011, 12:25 AM   #1
NISMO_tuner
NISMO_tuner's Avatar
Trader Rating: (64)
NISMO_tuner is an unknown quantity at this point
Feedback Score: 64 reviews
Send a message via Yahoo to NISMO_tuner
Z32 30mm calipers, drilled slotted rotors, conversion lines, front 5 lug
Z32 big brake upgrade for S13/S14
Front and rear calipers with drilled slotted rotors and conversion lines available.
Direct bolt on to S13 and S14. Calipers come with brake pads.
E-mail me for additional questions.
No lowballers but all offers will be considered.
E-mail: [email protected]
Z32 Front calipers - $300
-Aluminum 30mm
-Plenty of life on pads
-No missing parts
-Seals are in good condition
Z32 Rear calipers - $200
-Same description as fronts
Front drilled/slotted rotors - $120
-Great condition
-No cracks, uneven wear, or heat damage
-5 lug
-For use with 30mm calipers
Rear drilled/slotted rotors - $80
-Same description as front rotors
Front Ichiba 5 lug conversion hubs - $250
-Bearings in good codition
-Slight usage (low mileage)
-Studs in good condition
S13/S14 to Z32 conversion lines - $100
-Steel braided
-No leaks
-Direct bolt on from hardline to Z32 caliper
-Fronts and rears
Z32 Brake Master Cylinder - $60
-BMC50
-No third fitting
-No pigtail
-Cylinder only
Check my for sale thread for S13 parts
NISMO_tuner is offline   Reply With Quote
Old 07-06-2011, 02:35 PM   #2
NISMO_tuner
Trader Rating: (64)
Bump up
I'll include the conversion lines with the calipers
