Old 07-04-2011, 02:30 PM   #1
xiaphin
Trader Rating: (32)
xiaphin is an unknown quantity at this point
Feedback Score: 32 reviews
Send a message via AIM to xiaphin
1995 300ZX NA T-Top modded $3500
SOLD!!!!!!!!!!!
I am a straight shooter so what you see is what you get. Selling my 95' 300ZX NA T-Top. Cobalt Green with black leather interior. Car is fully loaded minus the Turbo option. I am second owner of the car, which was originally purchased at Nissan of Hickory located off of Hwy 321. Have pic of window sticker, price was $39,446.95. Have owners manual and will throw in the FSM as well.
all new pics here 1995 Nissan 300ZX NA pictures by xiaphin - Photobucket
older pics with t-tops out here
Older 300ZX Photos pictures by xiaphin - Photobucket
148,xxx miles on chassis - clean title
approx 25k on engine - rebuild was completed back in 2006
Asking Price is $3500 without wheels OBO
$4000 w rims OBO
-2 18x9 SSR Integral A2 +45 offset
-2 18x9 brand? +35 offset think they might be JIC, pops got them off E-bay and came off a Supra
PM me or e-mail [email protected] if interested or want more information
The Bad:
Passenger seat is on the way out - ripped
New TOB but still makes a little noise when cold
Door dings driver side.
Dent in drivers side panel behind door recently fixed at a shop - they dropped car off jack broke radiator and smashed undertray. They fixed the radiator tray is still busted.
Dent in passenger side rocker panel
Black trim pieces need to be painted or replaced (half chrome)
Missing one center cap - stole it for my s13
Missing 2 trim pieces on center console
A/C doesnt work. high pressure line has pinhole, wont hold a charge.
The Good Everything below:
Engine:
Fully rebuilt with approx 25k miles
New Rings, Rods, and mains
Block honed to remove glaze, factory spec
Heads magnafluxed
Valves reground to factory spec
New tappets
New water pump
All new water hoses ($800 from Nissan)
New factory injectors
New timing belt
New radiator
18" electric fan runs on thermostat
Stillen pop charger Part # 402900
Unorthodox Racing Underdrive pulley set (alternator, waterpump, powersteering, crank)
Part # UR041002602 from stillen
JWT Cams Part# AZ320-000S1
JWT Flashed ECU (rev limiter bumped to 8,000, top speed removed, and fuel map/timing curve optimized for premium fuel) Part# EZ323-NMF00
Stillen Headers Part # 503260
Stainless Steel Borla exhaust
Throwout Bearing Replaced when switched to lower mileage transmission (70K) - fresh fluid when installed
Fresh diff fluid - July
New Carrier bearing
Optima yellow top battery
Suspension:
Full ground control kit; Tokico 5-way adjustable shocks with Eibach drop springs
Upper adjustable control arms front (recently regreased)
All bushings up front are polyurethane
Strut tower bars front and rear
Stillen Sway bars Part # 304700
Adjustable Tension compression rods
Motul RBF 600 brake fluid
Interior:
Black leather interior w/suede
Power driver seat
Power mirrors also heated
Dual Air-Bags
Digital Climate Control
Cruise Control
Alpine CDA 9895 head unit (Factory Bose cd and cassete come with car if desired)
Apexi SAFC-NEO
Black Nismo shift knob if desired
Windows and hatch tinted at %35
Rims / Tires:
Stock Z32 wheels with BFG Sport 2 225/50/16 on all 4
Hawk HPS Pads - changed in august
Brembo Factory replacement Rotors - changed in august
Have 2 18x9 SSR Integral A2 +45 offset (not installed but available)
Also 2 18x9 brand? +35 offset think they might be JIC, pops got them off E-bay and came off a Supra (not installed but available)
Wet sanded hood with 2500 then buffed out with DA buffer. Just did this this weekend so all the other pics were taken before then.
Pics of Wheels on my 240 before it was stolen with the other half of these mix and matched rims below
Could only find one pic of the other pair of wheels. I have two but heres the pic
2018 Audi RS 3 | Unitronic Stage 1 ECU and Stage 2 TCU tune
xiaphin is offline   Reply With Quote
300zx, ssr, t-top, z32
