Old 07-08-2011, 07:06 PM   #1
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
JDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the roughJDMbyBlood is a jewel in the rough
Feedback Score: 24 reviews
**TRADE** 93 240 Coupe loaded with mods...
Trade must be equal in value/mods or close to it. Looking for RWD or 2 door AWD cars. (Already have a 4 door car.) No FWD cars....
(JDM light up tag does not come with car.)
Video of car at idle:
http://www.youtube.com/watch?v=yYwJNo_jELI
Some cars that I would be interested in, but not limited to:
-Classic Mini Cooper
-Classic American made car
-Datsun 510
-Subaru Impreza RS with turbo STi swap. (maybe)
-s13/s14 with a RB swap.
***** Here is the car I have to offer in trade****
1993 Nissan 240sx Modification list:
General Info:
-1993 Nissan 240sx
-Coupe
-Base Model 240sx.
-Aztec Red
-189,000 miles on chaises
-2000 miles or less on all Aftermarket/ Performance parts.
-2000 miles on TOTAL sr20det rebuild.
Engine: (Built SR20det Black Top)
-R.S. Enthalpy Tune w/ 2 Step Launch Control
-Nissan Z32 MAF
-Turbonetics t60 turbo
-GodSpeed Polished Stainless Steel Turbo Heat Shield
-Tial 38mm Wastegate (12lb Spring.)
-Kinugawa Oil Feed Line
-Wiseco Pistons
-Eagle Rods
-ARP Main Bolts
-ARP Head Bolts
-HKS Rocker Arm stoppers
-HKS Step 2 Cams
-Cosworth Head gasket
-Greddy Valve Springs
-Greddy High Capacity Oil Pan w/ Peak Performance Oil Drain Plug.
-Greddy Oil Catch Can (Machined 3 piece.)
-Greddy Oil Filter Relocation kit (K&N Oil Filter used.)
-Greddy Replica Polished Intake Manifold
-Greddy Oil Cap
-Circuit Sports Aluminum Pulley set
-Circuit Sports Aluminum CAS Cover
-Top Speed Engine Torque Damper
-Spectre Oil Filter Cooler
-Candy Blue Powder coated Valve Cover
Engine rebuilt with:
-Nissan OEM Timing Chain Kit
-Nissan OEM Water Pump
-Nissan OEM Oil Pump
-Nissan OEM Main Crank Bearings
-Nissan OEM Rod Bearings
-Nissan COMPLETE OEM Gasket Set
-Head Surfaced & Cleaned
-Blocked Decked, and Cleaned
Ignition System:
-Splitfire Direct Ignition System
-Circuit Sports Ignition Coil Ground Plate (Coil Pack Cover.)
Car Cooling System Set up:
Engine:
-Koyo Aluminum Radiator
-Greddy Radiator Cap
-Powered By MAX Coolant Swirl Pot.
-Flex-a-lite Electric Fans
-Flex-a-lite Mechanical Fan Controller
-Samco Upper/lower Radiator Hoses
-Stance Water Neck Adapter. (Temp Gauge Sensor Adaptor)
-Nismo Thermostat
-Circuit Sport Aluminum Over Flow Tank
-New OEM Temperature Sensors.
-Turbo:
-Pre Turbo Oil Cooler (Custom set up.)
-Custom Made Oil Lines.
-Power Steering:
-Power Steering Cooler
-SPAL 4" Electric Power Steering cooling Fan. 124 CFM Rating @ 1.9amps
Oil Cooler:
-Greddy remote oil filter adapter with Thermostat.
-Tomei 193068 N2 Super Oil Block Adapter
-12 Row Aluminum Oil Cooler 13.5" (L) 2"(W) 8"(H)
-6" Oil Cooler Electric Fan. 300 CFM Rating @ 4.8 Amps
-AN 10 Fittings through out.
-Stainless Steel Braided lines.
-Aluminum Hose Separator Fittings for Braided lines.
Intake/Intercooler Set Up:
-K&N Air Filter (RU-2520)
-CNC z32 Filter Adapter
-BMPC Bar & Plate intercooler
-Polished Aluminum Piping, Sections of IC Piping Custom made.
-DEI Cyro2 Intercooler Sprayer Kit. (Kit #080108)
-DEI Cyro2 3" Cryogenic Air Intake (Kit #080110)
-HKS SSQV Blowoff Valve (Super Sequential Blowoff Valve)
-T-Bolt Clamps through out. (Stainless Steel.)
Exhaust:
-CXRacing Top Mount Manifold (New Design.)
-Custom made Turbo Exhaust Pipe (Titanium Header Wrapped.)
-Custom made Wastegate dump pipe. (Titanium Header Wrapped.)
-Megan Racing Down Pipe
-Megan Racing 3” Test Pipe
-New Nissan OEM o2 Sensor
-Apexi N1 3” Cat Back Exhaust
-Apexi 155-A031 Titanium Slide Tip for N1 Turbo Muffler
-Circuit Sports Exhaust Hanger Bushing Kit (Set of 3)
Drive Train:
-Nismo Motor Mounts
-Nismo Transmission Mount
-Fidanza Aluminum Flywheel
-ACT HD Street Clutch Kit
-Stainless Steel Clutch Line
-Aluminum Drive Shaft
-J30 Rear End
-NEW Clutch Slave Cylinder
Fuel System:
-Power Enterprise 850cc Fuel Injectors
-Walbro 255 Fuel Pump
-Aeromotive Fuel Pressure Regulator w/ Gauge (Oil Filled.)
-300zx Fuel filter
-Circuit Sports CNC Machined Aluminum High Flow Fuel Rail
-Stainless Steel braded Fuel lines w/ AN Fittings
Suspension:
-Tein Flex Coilovers
-Tein EDFC (Electronic Damping Force Controller)
-Tein Front Strut bar
-Tein Rear Strut bar
-Yamato Garage Complete Multi Link Suspension Arms (Custom powder coated in Tein green.)
-Energy Suspension Bushing kit (Where applicable.)
-Tanabi Front Sway bar
-Tanabi Rear Sway Bar
-Tanabe Sustec Front Underbrace
-4 Wheel alignment performed by Vortex Motor sports
Brake System:
-300zx Master Brake Cylinder (z31 Remanufactured)
-Brembo 4 Piston Front Calipers ( 2005 Evo 8)
-300zx Rear Caliper (z32 remanufactured)
-Slotted/ Drilled Front Rotors
-Wagner Front Brake Pads
-Brake Motive Cross Drilled/Slotted Rear Rotor
-Evolution (brand) Ceramic Rear Brake Pads
-Circuit Sports Stainless Steel Brake Lines
-Megan Racing brake master cylinder heat shield
-GodSpeed Hydraulic Handbrake Kit.
-Carisma Hydraulic Handbrake Line Kit.
Interior:
-Godspeed 6 Point Roll Cage
AEM Gauges:
*True Boost, Controller/ Boost Gauge
*Wideband Meter
*Oil Pressure
*Water Temperature
*Voltage
- ATI ezPod Steering Colum Gauge Pod
-Aluminum Center A/C vent Gauge Holder.
-Blitz JDM VGTT (Voice Guide Turbo Timer)
-Pivot JDM Shift-light (Model ASL-X )
-Nissan Skyline R32 Seats
-MOMO Mod 80 Steering Wheel
-NRG Hub (Black)
-NRG Quick Release 2.5 (Blue)
-NRG Hub Lock (Black)
-B&M Short Shifter
-Custom made suede like shift boot
-GReddy Counter Weight Shift Knob
-Broadway Mirror
-Nissan OEM Fog Light Switch (Hard to find.)
-LED interior dome light.
Body:
-OEM Color Paint Job Using Nasen Paints:
*Complete Body Paint
*Engine Bay
*Door Jams
*Trunk Jam
***Silvia Front End Conversion***
-B-Wave Front Bumper (JDM)
-Chargespeed Rear Bumper
-Chargespeed Side Skirts
-Chargespeed 20mm Over front fenders
-Chargespeed Drift Hood (Fiberglass)
-AeroCatch Hood Latch 120-2100 Plus Flush With Lock Kit
-JDM s14 Kouki Wing (Custom Modified to fit.)
-Silvia Brick Head Lights
-NEW Silvia Head light Brackets
-NEW Silvia Corner lights
-NEW Silvia Half N Half Signal Lenses
-Silvia GT-R Grill
-Silvia Trunk Lock
-Origin Roof Spoiler
-Rear Fender Pull (Performed by S&R Performance)
***Note: The ONLY parts purchased USED for the Silvia conversion was the Silvia Brick Headlights, B-Wave front bumper & Grill. All other parts were purchased brand NEW.
Wheels:
-Rays Engineering Gram Lights 57F
*FRONT 18x8.5 +30
*REAR 18x9.5 +20
-Dunlop Tires
*FRONT 225/40/18
*REAR 255/35/18
-5 Lug Conversion (Rear z32 hubs, front Ichiba hubs.)
-Muteki lug Nuts, Closed End
Stereo:
-Alpine CDA-7894 Head Unit
-Alpine ERA-G320 Sound Field Processor
-Alpine CHA-S634 CD Changer
-Alpine SPS-171A 6.5, (2 Way Components)
-Alpine SPS-690A 6x9 (3 Way)
-Alpine SRW-1014D 10” Type R Subs
-Alpine MRP-F300 Amplifier (Mids and Highs.)
-Alpine M-2000 Amplifier (Subs)
-Sound Stream BX-10 (Digital Bass Driver.)
-Cadence CAP50F 50 Farad 24 Volt Capacitor with Dual Blue LCD Digital Meters (Amps and Voltage.)
-Optima Yellow Top Battery.
-STINGER SGP90200 CIRCUIT BREAKER 200 AMP.
-Stinger SGP32 PRO 200 AMP Battery Isolator.
-DB Bass & Stinger RCA cables.
Miscellaneous:
-Billet Power Steering Reservoir
-Custom Built Power Steering Reservoir Bracket.
-Sun Auto Hyper Voltage System GT
-ISIS Stainless Steel Braided Power Steering Line.
-Hella Horns
-Shuriken SK-BT20 Battery (Engine bay)
-Optima Billet aluminum Battery Mount. (Battery relocated to trunk.)
-125 AMP Nissan Quest Alternator w/ Cody ACE bracket
-Remanufactured SR Starter
-All NEW Belts
-NEW Front Lower Arms
-Fuel Pump Relay Mod
-Custom Made Intercooler Lower Support Bracket
-New Tie Rod Ends
-Top Speed s14 aluminum throttle pulley (Blue)
Alarm:
-Avital Alarm with power lock option.
*** The next 5 pictures below were taken this past 4th of July weekend.***
Listed below are the cons I feel should be noted.
-1 crack on dash.
-AC not installed. Have parts to install, but electric fan. Im Including a custom made AC line.
-Needs windshield molding/trim. (Removed when car was painted.)
-Has a few paint blemishes. (rock chips, a ding or 2 that was missed.)
-Small crack in passenger side skirt. (About 2" long.)
I've described the car and listed all the parts the best I can. May have forgoten a thing or 2 I’ve owned the car for about 6 years now. Since new, the car has been in a 30 mile radius of the Tampa, Fl area. NEVER been a Northern car. When I purchased the car, it was a bone stock base model 240sx with hub caps. As you can see in the pics the car has come a LONG way. The car has looked the way it does in the above pics for about a year or so and I’ve put about 1500-2000 miles on it. (Miles will go up as I do drive the car once in a while. The car is NOT my daily driver.) The car was built to be a overall fun car to drive that also looks as good as it drives. Have most receipts during build. Spent $28,000.00+ building the car. That includes the $2,600.00 I paid for the car. (Yea I got sick after adding everything up.) That amout did not include labor fees for the work I couldn't do my self. The car was **NOT** built to be a trailer Queen nor a Dyno Queen. I wanted to build a car that looked nice and that is fun to drive. I get compliments when ever I take it out. I’m over 40 years old and DO NOT abuse my car. Spent 2 much time and money to go and tear it up. I hope you will be honest in describing your trade. If you have any question, PM me and I'll do my best to answer them.
JDMbyBlood is offline   Reply With Quote
Old 07-08-2011, 07:48 PM   #2
240sx354
240sx354 is an unknown quantity at this point
Interested in a Built S14 with an S14 SR20det.?
240sx354 is offline   Reply With Quote
Old 07-08-2011, 09:37 PM   #3
one clean 300z
one clean 300z is an unknown quantity at this point
Trade for my Lexus is300?
one clean 300z is offline   Reply With Quote
Old 07-09-2011, 01:46 PM   #4
lovinmyz
lovinmyz is an unknown quantity at this point
http://zilvia.net/f/cars-sale/388826...c-ls1-t56.html
trade ls1 fc, let me know 267 467 5272
lovinmyz is offline   Reply With Quote
Old 07-09-2011, 01:53 PM   #5
psy
psy's Avatar
psy is an unknown quantity at this point
Call up a museum and sell it to them, have it put on a plinth.
This is a work of art!
psy is offline   Reply With Quote
Old 07-09-2011, 02:47 PM   #6
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
I wish more people would build cars like this.
Old 07-09-2011, 04:29 PM   #7
dazed
Trader Rating: (37)
dazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the roughdazed is a jewel in the rough
Feedback Score: 37 reviews
Very, very well built coupe you have sir.
GLWS.
dazed is offline   Reply With Quote
Old 07-09-2011, 04:40 PM   #8
boobs13
boobs13's Avatar
boobs13 is an unknown quantity at this point
Complete make over!
http://www.iwannagofast.net/
FOR SALE: DOHC maf, KA down pipe and SR A/C pump like new pm me for price.
cars are like beer, they all do the same thing, and we each prefer our own flavor...
boobs13 is offline   Reply With Quote
Old 07-09-2011, 06:47 PM   #9
alwaysideways14
alwaysideways14's Avatar
alwaysideways14 is an unknown quantity at this point
car is amazing ..GLWS
alwaysideways14 is offline   Reply With Quote
Old 07-09-2011, 07:56 PM   #10
Z FELLA
Z FELLA's Avatar
Z FELLA is an unknown quantity at this point
What about a straight sale? Message me the price or post it.
Z FELLA is offline   Reply With Quote
Old 07-10-2011, 07:04 AM   #11
EnvyS13
EnvyS13 is an unknown quantity at this point
If that is your scoob as well, i gotta say, your doing it right
EnvyS13 is offline   Reply With Quote
Old 07-10-2011, 02:13 PM   #12
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
Thanks for ALL the compliments guys. I REALLY appreciate it.....Wanted to give you guys an idea what the rear seating area looks like in the car since I didn't post a picture up above. I still have the the rear seats. As you can see I have my amplifiers, capacitor and subs in the rear seating area. Built by yours truly... The amplifiers shown in the picture are not coming with the car. Sold to replace with BRAND NEW Alpine amplifiers. (Still new in the box. Wanted to go with ALL Alpine.) Reason for going with the amplifiers/subs in the back seating area was with the aftermarket seats, NOBODY can get in the back, so not to waste the back seating area the amps, capacitor and subs went in the rear. Better weight distribution....
Old 07-14-2011, 06:50 PM   #13
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
Still available and looking to trade......
Old 07-15-2011, 08:51 AM   #14
wheelspin
wheelspin is an unknown quantity at this point
where at in FL are you located?
wheelspin is offline   Reply With Quote
Old 07-15-2011, 08:55 AM   #15
wheelspin
i apololgize i see you put near tampa. Very clean GLWS
Old 07-15-2011, 08:58 AM   #16
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
Tampa bay area
Old 07-15-2011, 12:40 PM   #17
h2v7
h2v7 is an unknown quantity at this point
why are you trading car looks niiice
h2v7 is offline   Reply With Quote
Old 07-15-2011, 12:43 PM   #18
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
Looking for something different.
Old 07-15-2011, 12:45 PM   #19
h2v7
kinda did all there is to do huh?
what do you estimate the value of the car at?
Old 07-15-2011, 12:51 PM   #20
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
If I end up keeping it, I'll put a larger turbo on the car. (Looking/shopping around now.) As for the value, Im not really sure. NEVER spent this kind of money on a car to turn around and sell it. *LOL* Really don't know how to put a value on it. I even thought about parting it out. It may be the best way to get the most money out of it. I guess value would be what somebody is willing to pay.
Old 07-24-2011, 06:16 PM   #21
v8kllr240sx
v8kllr240sx is an unknown quantity at this point
Great guy great car somebody buy...but if you do.decide to part out make sure you call me first :-)..big turbo coming soon
v8kllr240sx is offline   Reply With Quote
Old 07-25-2011, 10:05 PM   #22
325iturned240
325iturned240 is an unknown quantity at this point
are you willing to trade for my 325i its an 04 sliver grey 5 speed???
325iturned240 is offline   Reply With Quote
Old 07-26-2011, 04:00 PM   #23
Xclusive_racer
Xclusive_racer's Avatar
Xclusive_racer is an unknown quantity at this point
Great car super legit guy!
You Build Cheap! Your Car Will Feel and Drive Cheap!
Xclusive_racer is offline   Reply With Quote
Old 08-01-2011, 12:50 AM   #24
silcoupe
silcoupe's Avatar
silcoupe is an unknown quantity at this point
Have a few questions but won't let me pm you pm me please
silcoupe is offline   Reply With Quote
Old 08-01-2011, 06:21 PM   #25
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
At the moment the car is going through a couple changes and adding a part or 2. Car may be no longer available for now, but that all depends on the trade. Some of the changes include Skyline r32 GT-R seats, Powered by Max coolant swirl pot, Whistler PRO-3450 Remote Radar Detector and a Turbonetics t60 top mount set up.....
Old 08-02-2011, 02:33 PM   #26
C-BASS
C-BASS's Avatar
C-BASS is an unknown quantity at this point
If interested, I have a 2003 Lexus is300 5spd with some nice mods for trade. Plz text me @ 904 402 1728 if interested. Thanx.
C-BASS is offline   Reply With Quote
Old 08-02-2011, 05:20 PM   #27
living4surf
Trader Rating: (52)
living4surf is an unknown quantity at this point
Feedback Score: 52 reviews
Interested in a s14
http://zilvia.net/f/cars-sale/390912...bm-origin.html
living4surf is offline   Reply With Quote
Old 08-27-2011, 05:55 PM   #28
JDMbyBlood
JDMbyBlood's Avatar
Trader Rating: (24)
In the process of installing the top mount set up.(Skyline r32 GT-R seats, Powered by Max coolant swirl pot installed today.) Ran into a issue and it may take longer than expected to install the top mount. Thought Id go ahead and link a video of the car before removing the t28 set up. This is just a short video of the car at idle.
sr20det with HKS step 2 cams and Apexi N1 Exhaust - YouTube
t28 vs. Turbonectics turbo
Old 08-28-2011, 08:26 PM   #29
s13_rb25
s13_rb25 is an unknown quantity at this point
I have a 1990 s13 hatch. uncracked dash. full black interior. Has Side Skirts and rear bumper, but not a front. its a rb20 with mckinney mount kit.
BRAND NEW PARTS LIST (0 MILES ON THEM)
Spec Stg 3 Clutch kit
3" downpipe
17x9.5 +12 rota grids
mishimoto water temp housing.
other misc parts that were on my last car
isis dual straight pipes cat back 3"
3" test pipe
isis fuel pump
flip out touch screen dvd player
front mount intercooler
theres a bunch more missing
by the time car will be traded it will have brand new 20mm wide front fenders (pop up) and car will be repainted red.
s13_rb25 is offline   Reply With Quote
Old 08-29-2011, 07:02 AM   #30
skazat
skazat is an unknown quantity at this point
im finishing up a rb25 swap on a s14 let me know if your interested in talking about it.
skazat is offline   Reply With Quote
