Old 07-10-2011, 03:34 AM   #1
Noxy
Noxy's Avatar
Trader Rating: (18)
Noxy is an unknown quantity at this point
Feedback Score: 18 reviews
s13 Please clear my garage! (KA,CA,RB,B13,S13)
Hey guys. Still trying to get rid of this stuff. Feel free to make an offer if you think the price is too high, and of course the more stuff you get the cheaper it will be. First off, my contact information and pictures:
Shipping: Yup. At your expense.
Pick-up: Nope.
Email: [email protected]
Paypal: Same as email.
CA18DET Parts
Item: Throttle Position Sensor
Description: Used. Got as a spare with my engine, never used it so don't know if it works.
Price: $22 shipped
Item: Plenum Gasket
Description: New Fel-Pro. This is the gasket that sits between the two manifold pieces. I only needed the 8-port gasket.
Price: $10 shipped
RB20DET Parts
Item: SMIC
Description: Used. I got this from a RB20 swapped Z a while back and it worked just fine. Comes with the brackets and air duct.
Price: $30 shipped
KA24DE Parts
Item: Fuel O-rings
Description: New Fel-Pro. I only needed the cushions from this kit, but the 4 small and 4 large O-rings for the injectors are still new.
Price: $6 shipped
Item: Cooling Fan
Description: Used from my car. Just fan, but no clutch. No cracks, just a little dirty, and never had a problem.
Price: $11 shipped
Item: MAF Sensor
Description: Used from my car. Pulled from perfectly running car.
Price: $20 shipped
Item: Manifold Gasket
Description: New Fel-pro. I only used the plenum gasket, so this is only the intake manifold-->head gasket
Price:$10 shipped
Item: Valve seals
Description: New Fel-Pro. Exhaust and Intake valve seals.
Price: $25 shipped
Item: Ignition Coil
Description: Used from my car. Never had a problem.
Price: $13 shipped
S13 Parts
Item: Vented Headlight cover
Description: Used. Passenger vented cover that I bought thinking it was the driver side way back when. Has one broken mounting tab, but still sit fine.
Price: $17 shipped
Item: Top Fuel Turbo Timer
Description: Used? It's out of the box, but the previous owner never used it and neither did I. Has the plug and play harness with it.
Price: $42 shipped
Item: Box of differential parts
Description: Used. Came out of an open differential.
Price: Make an offer!
Item: Ring gear and Bolts
Description: Used. Out of the same diff. Will sell the bolts separate if you want.
Price: $20 shipped
B13 Parts
Item: NGK BKR5ES-11 Spark Plugs
Description: New. I got these plugs to put in my NX1600, but was stolen. For GA16DE.
Price: $10 shipped
Item: Raybestos Brake Pads
Description: New. Something else that was going on the NX before it went bye-bye. Service grade.
Price: $15 shipped
As Always Trades will be accepted in the form of...
-CA18DET parts such as, but not limited to, clutch fan, a banjo bolt for coolant line, maf adapter, compressor outlet pipe, stock flywheel, etc.
-B15 Spec-V parts
-Catch can
-and, of course, Rockstar Cola!
I'll add more stuff as I find it. Best way to get a hold of my is to PM me, but if you feel the need send me an email. Thanks!
Noxy is offline
Old 07-10-2011, 10:41 AM   #2
whomiked
whomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choiceswhomiked has made poor choices
Happen to have a Vlsd or Ka Tranny? I'm also located in Omaha.
whomiked is offline
Old 07-14-2011, 07:03 AM   #3
Noxy
Noxy's Avatar
Trader Rating: (18)
Bump waffles
Noxy is offline
Old 07-18-2011, 12:04 AM   #4
Noxy
Noxy's Avatar
Trader Rating: (18)
To the top...
Noxy is offline
Old 07-18-2011, 01:12 AM   #5
NOLAG
NOLAG is an unknown quantity at this point
how much for the ecu shipped to 10305?
NOLAG is offline
Old 07-25-2011, 08:16 AM   #6
Noxy
Noxy's Avatar
Trader Rating: (18)
Ecu sold and last bump i think...
Noxy is offline
Old 07-25-2011, 06:40 PM   #7
racerx2k1
460
racerx2k1's Avatar
Originally Posted by Noxy View Post
Bump waffles
To the top...
racerx2k1 is offline
