Old 11-06-2003, 07:27 PM   #1
ucfz31s13
ucfz31s13 is an unknown quantity at this point
Send a message via AIM to ucfz31s13
17x8.5 +25 up front on s13? DT-05R's...
Decided (w/ the help of dousan) that 17x8.5 +25 in the rear will be nice w/ a little fender roll...Now up front, should I opt for the same, or go w/ 17x7.5 +15. I plan on getting the fronts pulled as well, so should I stay w/ 8.5 +25 on all corners?
Need to hurry up and decide so I can send money, hehe.
Thanks
z
ucfz31s13 is offline   Reply With Quote
Old 11-06-2003, 07:42 PM   #2
JasonNagra
JasonNagra is an unknown quantity at this point
Send a message via AIM to JasonNagra
Ya go 8.5 +25 all around.
http://www.imagestation.com/picture/...f/f9dc7664.jpg
Edit: check your link.
JasonNagra is offline   Reply With Quote
Old 11-06-2003, 07:47 PM   #3
KiDyNomiTe
KiDyNomiTe's Avatar
KiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond reputeKiDyNomiTe has a reputation beyond repute
Send a message via AIM to KiDyNomiTe
Well do the math. The pics below are F: 16x7.5+22 R: 16x8.5 +37
How much camber are you running? The cars in the pics look close to 0, hard to tell in the pics. If you are running close to stock cmaber then +25 in the rear will be 12 mm out (about half an inch).
About how many more mm does pulling em out give you? The white hatch could use a couple mm in the rear depeding on how flush you want em.
Fronts look good though, and if you get 7.5 in +15 it'll be 10mm, which would again could look good, but I don't know how many mm pulling gives. If you are running a lot of camber in the front it won't be the best looking setup with pulled fenders.
There are too many factors with offsets and being flush, I think if you do get the +15 7.5s you wont be pulling the front fenders.
PROCEED
Grip Gambler
KiDyNomiTe is offline   Reply With Quote
Old 11-07-2003, 01:07 AM   #4
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
The cool thing about having the same size is being able to rotate the tires. If I were you, I'd go same size front and back.
Flybert is offline   Reply With Quote
Old 11-07-2003, 08:17 AM   #5
Ranger_Man
Ranger_Man is an unknown quantity at this point
Send a message via AIM to Ranger_Man
rather than start another offset thread ill just post here.
would 17x8.5 +25 F and 17x9.5 +30 R work well for s14? looking perfectly flush doesnt concern me as much as clearing coilovers does.
TIA
Ranger_Man is offline   Reply With Quote
