Old 07-12-2011, 03:50 PM   #1
95zenkisr20
95zenkisr20 is an unknown quantity at this point
sr20det locked up leaky injector HELP!!
so today i picked my car up from paint and had to bump start to get home because starter was bad. noticed it was running bad or bogging after i got up to speed it was fine. found out it was a leaky injector very leaky poured half gallon of gas in intake manifold and in cyinders 2 and 3 so i drained the oil took allll the gas out and now it seem like my motor is seized up cannot budge it at all a breaker bar on crank pully didnt work trying to push it and bump start didnt work (key off of course) and the rotating assembly just wont budge. even poured oil down the cylinders to loosen them up nothing it is stuck any help is much appreciated
95zenkisr20 is offline   Reply With Quote
Old 07-12-2011, 03:52 PM   #2
JDMRIDDAZ
JDMRIDDAZ's Avatar
JDMRIDDAZ is an unknown quantity at this point
try turning both ways tho
this happened to me and i did the same cleaned all gas out and she was fine
シチサn w/ka20det:in progress
シチサnw/sr20det:stolen
JDMRIDDAZ is offline   Reply With Quote
Old 07-12-2011, 04:10 PM   #3
Sileighty_85
Sileighty_85's Avatar
its out of gear right? lol
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-12-2011, 04:36 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
if you hydrolocked the engine and bent a conrod, time for new engine.
like the other guy said, try turning it both directions, with spark plugs removed.
Old 07-12-2011, 05:02 PM   #5
95zenkisr20
did all that already wont budge i drove it home and shut it off and then found out it was leaking gas then i took all the gas out and now it wont budge
Old 07-12-2011, 05:15 PM   #6
brndck
brndck's Avatar
sounds like you bent a conrod.
or ate a valve.
something is mechanically binding, preventing the engine from rotating.
Old 07-12-2011, 07:09 PM   #7
95zenkisr20
how is that possible i drove it home perfectly fine running on the highway and then i try to start again and nothing? locked up? something isnt adding up
Old 07-12-2011, 10:53 PM   #8
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
Well first off, you can't diagnose it with "Bump Starting".
Stop being a cheapass and get a new starter. If I'm not mistaken, the number one issue that flooding an engine causes is a bent rod. If you were leaking shittons of gas, that is very possible.
However you seem to be the type who would rather 'bump start' their car, causing it to start with 0 oil pressure, rather than spend 50 bucks and get a working starter.
Did you know this injector was leaking?
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 07-12-2011, 11:24 PM   #9
95zenkisr20
the starter is BRAND NEW actually just got it today from fr sport and i just found out about the leaking problem when i got it back home from paint because i was wondering why the car would bog and such and then when i went to go try to start it again to diagnose ....Locked up then after having the key on i started to notice gas pouting out a breather on the Throttle body
Old 07-12-2011, 11:25 PM   #10
95zenkisr20
Originally Posted by sileighty_85 View Post
its out of gear right? Lol
......... -_-
Old 07-13-2011, 06:33 PM   #11
Kingtal0n
Kingtal0n's Avatar
If a cylinder fills with gas and you turn the engine over, like someone said already, it can bend the parts inside the engine, and lock the engine. If all the spark plugs are out, and the engine will not turn in any direction, something is probably bent inside.
