Old 07-13-2011, 09:38 AM   #1
Nismobound
Nismobound's Avatar
Nismobound is an unknown quantity at this point
CA 97' KA24DE REBUILT. VERY CLEAN WIRE TUCKED 2k Miles on Engine. W/ Tranny
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
Hello everyone..
I'm not making a long add today but there are many pictures for you to view.
I have a rebuilt KA24DE W/ Tranny off a 97' 240sx.
WIRE TUCKED WHOLE ENGINE.
NOT SMOGG LEGAL!!
Because it has all the smogg equipment taken off and properly blocked off for most responsive power. AND ETC Illegal parts.
Engine parts & ETC.
NEW head, Valves, Springs, Timing Chain, Timing Chain guides, Piston Rings, Oil squirters, Oil Pan, Balanced crankshaft off Ebay with bearings main included, connecting rod bearings and caps, Head gasket, ARP head studs, Injectors, NGK Spark plugs and wires, Solid Engine mounts.
Engine accessories that come with the deal!
Megan Headers, Megan Flex pipe, Megan Test pipe, Mishimoto Radiator and Hoses, Wrinkle coated Valve cover and Intake manifold ( Reduces heat ) Air Intake, MAF, Fuel Filter ETC.. Will add more.
Transmission
NEW Clutch, Flywheel, Rebuilt Transmission & Solid tranny mount
I'm sure i have a few more things to add but this gives you a solid understanding this engine is strong, pretty fast for a KA, it can beat a SR off the line forsure only for a few seconds lol... but regardless a very good drifting engine.
Reason for selling is because my built SR is ready for installation on my car and i have no room to store this engine. Wish i could tho!
The Good: $650 NON NEGOTIABLE- Engine & Tranny will be taken out for you!! Everything needed to make it run! 100% Running!
The BAD. Has a broken valve spring. Maybe 2.. NO AC/HEATER... ( still has blower.) It could use aftermarket valve springs in my oppion because engine has such torque and power it doesnt open and close fast enough. Good Springs will help the valve close faster. Engine still runs, Driveable but fix the springs!
Very good racing engine or daily driver, It has 1700 miles on it and the transmission.
Engine pick up will be located in Stockton CA.
Q's can be PM'd to me thru Zilvia or Text 707 583 6640 or Email: [email protected]
Thanks, D
Nismobound is offline
