Old 11-07-2003, 02:33 PM   #1
drpimper746
drpimper746 is an unknown quantity at this point
ACT 6 puck for sr
what do u think about a ACT heavy duty preasure plate with a 6 puck disk. phase2motortrend is using it in there race car. any suggestions?
drpimper746 is offline   Reply With Quote
Old 11-07-2003, 06:05 PM   #2
Evil S14
Evil S14 is an unknown quantity at this point
Send a message via AIM to Evil S14
hey justin, use the search function
*image exceeds forum limit*
-Moderation
Evil S14 is offline   Reply With Quote
Old 11-07-2003, 06:51 PM   #3
HiPSI
HiPSI is an unknown quantity at this point
Send a message via AIM to HiPSI Send a message via Yahoo to HiPSI
not a good choice for a daily or semi daily driver. unless you need to hold 450+ft/lbs of torque.
SR motor set/clip $2500+, FMIC kit $700+, Downpipe $100+, 3" exhaust $500+, Misc install parts $100+, Shop labor for install $1000+ and you still only make 220rwhp for $5000
so what's so CHEAP about the SR swap again?
HiPSI is offline   Reply With Quote
Old 11-11-2003, 01:13 AM   #4
NISMOoPW
NISMOoPW is an unknown quantity at this point
Send a message via AIM to NISMOoPW
Had it on the KA
I'd recommend it, that clutch package totally kicks the nuts out of most. I had it on my 12valve and it by far made the car just THAT much more enjoyable to drive. Although... I am a super beefy track/soccer leg having monster. Get it, and you won't be disappointed...unless you have girly legs...
NISMOoPW is offline   Reply With Quote
Old 11-11-2003, 08:26 PM   #5
Var
Var's Avatar
Var is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of lightVar is a glorious beacon of light
Send a message via AIM to Var
Dont get a clutch that is too powerful, cause it will put unnecessary wear on your drivetrain. If you plan on pushing what the clutch is capable of then get it. If not get a centerforce or any full disc clutch. Puck clutches are no-no in my book unless you're drag racing.
Hi
Var is offline   Reply With Quote
Old 11-12-2003, 03:05 AM   #6
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Can you explain why having a clutch that can handle 300 lbs/ft of torque would be worse for let's just say a stock KA. It doesn't make sense to me. Why would having more power protect your tranny any more. Thanks in advance.
Flybert is offline   Reply With Quote
Old 11-12-2003, 10:52 AM   #7
Var
Var's Avatar
The higher torque capacity your clutch has, the stronger the springs on the pressure plate are. Also the friction material on the disc is more grabby. This put extra stress on your transmission. Especially when it comes to a 6-puck that has shitty engagement. Having more power wont save your tranmission but there's no point in having a better clutch till you have the power to put down. Especially on a KA where 95 percent of KA motors out there can do fine with a stock clutch setup. Hey take it from the Drift King(not me lol) he says always use a clutch to fit your needs and nothing more.
Hi
Old 11-12-2003, 12:14 PM   #8
SpeedMonkeyInc
SpeedMonkeyInc's Avatar
SpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond reputeSpeedMonkeyInc has a reputation beyond repute
I had a 6 puck on my last car. Trust me, unless its a track car you really don't want it.
I full face sprung hub will be the way to go and will hold all the power the average user can throw at it. Just get a heavy duty pressure plate and you will be fine.
SpeedMonkeyInc is offline   Reply With Quote
