Old 07-14-2011, 07:45 AM   #1
mocmiranda
mocmiranda is an unknown quantity at this point
Rb20det experts HELP ME PLEASE!!!
The car : 240sx with rb20det tranny
The problem: the s13 vehicle speed sensor works , reads 0.5 on multimeter, registers speed when spun by hand , pinion gear is not chewed up, what is wrong ??
Is there a way I have to install the speed sensor into the rb20 tranny , it fits perfect , bolts down and everything but when I drive nothing .
Any ideas ?
mocmiranda is offline   Reply With Quote
Old 07-14-2011, 08:03 AM   #2
lilrussian
lilrussian is an unknown quantity at this point
Have you checked your gauge cluster? have you checked the wiring all the way from the speed sensor to the gauges?
lilrussian is offline   Reply With Quote
Old 07-14-2011, 08:49 AM   #3
mocmiranda
Vss
Yes sir , everything fine from vss up to gauges , when I turn the red pinion gear ; it registers speed on cluster , just when I put it in the tranny , nothing
Y/L and y/b are the wires for my cluster dohc digital, and I know I know those cluster go bad with the intermitten working lol
But it a good cluster , I've tested it many ways. Just seems weird I can do it manually but not when it's in the tranny
Old 07-14-2011, 10:28 AM   #4
lilrussian
Sounds weird, my buddies RB20 in an s13 used the manual gauges from a dual cam and used an S13 speed sensor and the speed was right on.
What speed sensor you using? the teeth might not be hitting the gear inside the tranny.
Old 07-14-2011, 10:46 AM   #5
mocmiranda
Vss
That's what I'm thinking too , but not sure why .
I'm using a s13 manual tran vss with red pinion gear teeth (20),aluminum outer shell I mean it's pretty much new .
The rb20 vss has 21 teeth but the vss's look identical in shape and everything .
Could you ask him if he attached a screw to hold it Down?
Or turned it another way to touch the inside gear of tranny?
Or did anything else ?
Old 07-14-2011, 11:05 AM   #6
lilrussian
Yeah I will ask him and a local RB guy aswell, see what they say.
My s14 RB doesn't have a speed sensor yet so I haven't personally did one haha
I'll get back to ya as soon as they text me back.
Old 07-14-2011, 11:56 AM   #7
Vernal
Vernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymoreVernal is not welcome here anymore
Send a message via AIM to Vernal
lift the wheels up and spin em, and check for a variance in voltage coming to the cluster. I remember the vss out of my SR had flat spots on the very end. the speedo stays at 0?
Vernal is offline   Reply With Quote
