Old 11-09-2003, 10:27 AM   #1
Spins
Spins is an unknown quantity at this point
SR What should my oil pressure be on a SR?
I have 95SR20det Auto.I'm using an AutoMeter electronic oil pressure gauge 100psi max. When I start the engine and it's cold I get around 65 to 75psi on the gauge. As the car warms up my oil pressure decreases. I know this is normal. But after driving it drops to around 15psi at idle. My oil light on the dash never comes on or anything.I just think this is kind of low oil pressure. Under normal driving conditions or if you tap the gas pedal the oil pressure goes back up right away. My oil pan had a dent in it. That was corrected. I am using an oil filter relocation kit with a larger than stock (STP)filter. I have the oil pressure sending unit installed in the line between the filter and the engine.I'm using Mobil One 10-30 syn. oil. Could any of this be a problem? What should my oil pressure be at idle?
Spins is offline   Reply With Quote
Old 11-09-2003, 02:09 PM   #2
HaLo
from Canada, eh!
HaLo's Avatar
HaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfectionHaLo is close to perfection
Send a message via ICQ to HaLo Send a message via AIM to HaLo Send a message via MSN to HaLo
Pressure at idle once warm: ~1kg/cm2 ~ 15psi
3K RPM: 4kg/cm2 ~ 60 psi
-> HaLo
Race Car: '98 E36 BMW M3
Daily Drivers: '23 Audi Q4 e-tron & '13 VW Touareg
SOLD: 01 GPW Honda S2000
PARTED: 93 Pearl White 240SX LE Fastback w/SR20DET
SOLD: 93 Super White 240SX SE Convertible w/Silvia Front
HaLo is offline   Reply With Quote
Old 11-09-2003, 03:55 PM   #3
Spins
oil pressure
Cool, so I'm running normal.Good to know. Thanks for the info.
