Old 07-30-2011, 05:13 PM   #1
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
Need it all gone!!! New Seats, Leftovers, Wheels etc!
EVERYTHING is OBO. Shipping is not included but it will either be USPS Parcel or Priority unless its too big. Keep offers inline with what this shit goes for...There is a PO on base so everything ships the next day M-TH. Everything is from an s13 hatch with redtop SR.....MAKE AN OFFER ON ANYTHING!!! All this shit has to go. PM is the quickest way to get a hold of me.
Trades....All I need is an SR Redtop AC bracket/tensioner and bolts
As far as offers go I am more then willing to be flexible and work with you especially if you want more then one item and the used stuff.
New Stuff (only whats listed below is for sale):
ES Rear Subframe Inserts - brand new $10
ES Rear sway bar bushings - brand new (no end link bushings) $10
ES Front Sway Bar Bushings - brand new (non hicas) $15
ES Toe and RUCA Bushings brand new - $15
C-tek pads for front calipers - brand new $25
Front ABS Rotors (2) - brand new Slotted, centric blanks $80
Rear Rotors (2) - brand new Slotted $45
Circuit Sports Sr20 Pulley Set Polished Silver - Water Pump Pulley Mounted but didnt like the look, $70 firm shipped
Circuit Sports Angles Oil Block Adapter - $65 firm shipped
F1 Spec Type 1 Seat (NO BC RAIL ITS GONE)- Brand New! Have universal shit that came with them as well. $165
-6an 90 degree for power steering - with a used SS hose and 45 deg -6an already attached to make a HP PS Line.$35 for everything
Used Stuff (only whats listed below is for sale):
OEM Front LCA's - needs new ball joints
OEM RUCA's - with ecentric bolt
OEM ABS Front Calipers
OEM ABS pump - the main unit in the enginebay for abs
OEM ABS controller/ecu - mounts inside the car
OEM ABS MasterCylinder
SR Oem Rods - in good shape, pistons attached but cant remove or you can have both. 1 piston shot.
SR Timing Set - from motor before rebuild
ARP Sr20 Head Studs - 2 were stuck and used vise grips in the center (no damage to threads) to remove. Otherwise everything's there and fine.
2 Sr20 coil packs
Enkei 17x7 black/chrome 4x114.3 Offset is in the 40's. This set is your standard cast enkei wheel that. The rears have 245/45/17's Scorcher TA's on them and the fronts have 215/45/17's Gforce sport. Both sets of tires in good shape...You can run them ASAP. They aren't perfect but hey the tires alone are worth it and the pics show they are in pretty good shape. $$275
niscur29 is offline   Reply With Quote
Old 07-30-2011, 08:57 PM   #2
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
Price of 2 Coil Packs shipped to 98277.
EvoVIII808 is offline   Reply With Quote
Old 08-03-2011, 01:24 PM   #3
niscur29
Bump numba 1
Old 08-07-2011, 01:21 PM   #4
240sxdrifted
240sxdrifted's Avatar
240sxdrifted is an unknown quantity at this point
Hey man I believe I still have redtop ac bracket and tensioner...needing some seats or a seat....where are you located??? Andrews???
240sxdrifted is offline   Reply With Quote
Old 08-07-2011, 01:23 PM   #5
240sxdrifted
Hit me up with a pm
Old 08-19-2011, 01:23 PM   #6
niscur29
Bump numba 2
