![]() Join Date: Jul 2005
Trader Rating: (354)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 354 reviews
![]() Testing Waters Testing Waters Testing Waters Testing Waters
1989 Nissan 240sx Hatch Power Windows,Locks,Mirrors Cons -Very Few Dents/Dings -Salvage Title(Was told for theft back when it was stock years ago) -Needs Paint -"Zilvia Starter Package"- Look at my Trader Rating and join date and you'll see I've been around ![]() Engine/Performance: S13 SR20det Red Top Only ran Mobil 1Full Synthetic 10w30(just changed (7/30) Brand New CAS Brand New TPS Brand New IACV Brand New Fan Shroud Brand New Gates Micro V Belts Brand New Black Silicone Hoses Brand New Coolant Overflow Tank Brand New OEM timing Chain Tensioner Brand New S14 SR Water pump Brand New Walbro 255lph Fuel Pump Brand New Fuel Filter Greddy 52mm Black Electric Oil Pressure Gauge Greddy 52mm Black Electric Water Temp Gauge Greddy 52mm Black Electric Boost Gauge 3 Row CX Racing Radiator Nismo Thermostat All New 7 layer S15 Exh. Manifold gaskets and turbo gaskets Metal Headgasket(unknown brand) S15 Spec-R Garrett T28 HKS Wastegate Actuator Earls SS Oil and Coolant lines ARC BOV Greddy Intercooler Nismo 740cc Injectors N62 Maf OEM Mazda Miata Battery(1 yr old) RS-Enthalpy Tuned Ecu(740cc,T28, 14 psi) Apex'i Filter Tomei Intake Adapter Aftermarket Elbow Megan DP Catco 3" high flow cat Blitz JDM 3" Exhaust(cut and welded to sit higher) 14lb Flywheel 6 Puck Clutch PBM Magnetic drain plug Circuit Sport short Shifter Suspension/Brakes: Brand New PBM Coilovers(probably 600 miles on them) Nismo 2 way LSD JDM Diff w/ 5 bolt axels and diff cover SPL Version 1 Toe Rod's SPL Version 1 Traction Rod's Kazama RUCA's Circuit Sport Tension Rods Johnny Fraz Tension Rod Brace(Like Nismo Brace) Tein Inner Tie Rod's Tein Outer Tie Rod's Energy Suspension outer tie rod boots Energy Suspension Front Sway bar bushings/endlinks Energy Suspension rack & pinion bushings Front Strut Bar Z32 Rear 5 Lug Hubs Aftermarket 5 Lug Front hubs Z32 30mm Front Calipers w/ss lines Project Mu Pads(Front) BRAND NEW SS595 Federal 215/40/17 tires(Maybe 400 miles) MB Battles(17x9.5 +15 offset) in bright silver Slip on 10mm spacers front 20mm Custom Adapters in rear) Exterior: Kouki OEM Bumper(New) Kouki OEM Turn Signals(New) Kouki OEM Position Lights(New) Kouki OEM Extensions(New) Kouki OEM Extension Brackets(New) Kouki OEM Sideskirts Kouki OEM Valences(missing center ![]() Kouki FPR OEM Style Spoiler Kouki FPR OEM Style Lip(Vanquish?) Kouki OEM Tail lights Glass H4 Housing Headlights Slim 6k HID Interior: Full Interior S14 Manuel Seat Belts Clean Black Dash Nardi Classic(kind of beat) Works Bell Hub Newish Turn Signal and Wiper Stalk Nismo Shift Knob New Leather Shift boot F1 Spec Sidemount Seat F1 Spec rails S14 Passenger seat Pioneer Speakers Center Gauge Pod w/ Greddy Gauges DOHC Cluster w/ SR RPM Price: Reasonable offers! None of that B.S. saying "Oh its salvaged" because the frame is very straight and a CLEAN TITLE doesn't always mean its legit(you don't have to go through insurance or even dmv if you crashed/got hit and someone took off,etc) Also, I might be looking for a trade so let me know what you have. Equal value please. Recent Pics: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Driven08; 08-07-2011 at 03:09 PM.. |
