Old 08-07-2011, 03:19 PM   #1
j0ey
j0ey is an unknown quantity at this point
s14 95 ka24de engine wont stay running
My 1995 ka just got its timing redone (not sure if it was 100% right although done professionally) and all new seals. I drove the car for about 2 days and while i was sitting still at lights it started bogging down and would stall out if i didnt tap the gas a bit. So now my dilemma is that i was driving to a buddies house and downshifted from 2nd to 1st and the car started jerking and started bogging a whole lot worse and then stopped running. I sat there for about 20 minutes, cranked the car again and somehow found a sweetspot in the pedal to drive the car about an 1/16 mile to my friends house at under 1500 RPM's, the car has not been able to drive more than 20 yards since. Now when i crank the car it will turn over but as soon as i crank it, the RPM's are around 500 or less and will not fully crank up or stay running
please help, if you need more info i will gladly give it, this is a good as i can come up on a wim right this second
j0ey is offline   Reply With Quote
Old 08-07-2011, 03:25 PM   #2
94spitfire91
94spitfire91's Avatar
94spitfire91 is an unknown quantity at this point
By done professionally I assume you meant at some shop. Well tell them your experiencing these problems maybe they know. Considering it started doing this soon after you got it back from them it could have very well been there fault
94spitfire91 is offline   Reply With Quote
Old 08-07-2011, 03:31 PM   #3
Taylor008
Taylor008 is an unknown quantity at this point
Fool pump, foo.
Maybe. Check fuel pressure.
Taylor008 is offline   Reply With Quote
Old 08-07-2011, 03:47 PM   #4
j0ey
thanks for the replies, hes open mon-fri so im bringing it there tommorrow, and i checked the fuel filter did a mini crank and he fuel is coming out just fine, it feel to me like the air/fuel isnt doing the right thing, but im just a noob
Old 08-09-2011, 03:00 PM   #5
j0ey
incase anyone was wondering, i checked my ecu codes and it seems to be quite simple.
12- MAF sensor
34- Detenation (knock) sensor
41- Intake air temp sensor
ill be picking these up soon and ill post a little video
