Old 08-11-2011, 04:38 PM   #1
Shouldahadav8
Shouldahadav8's Avatar
Shouldahadav8 is an unknown quantity at this point
S14 Blacktop SR20DET Motor/Trans+extras $750
s14 notch top Sr20det motor with (2) working 5 speed tranny's , a built max port and polished head with 3 angle valve job, ARP head studs, rocker arm guides, comes with everything I have for it ( IE: ps pump, starter, coil packs, CAS, ETC ETC)
It Spun #3 Main Bearing, the head was pulled for inspection so it needs a headgasket, and a water pump. if you look at the pics there was ZERO sediment behind the water pump showing that the motor was rebuilt/ hot tanked less thank 10K miles ago. you
NO SHIPPING, NO PART OUT, LOCAL PICK UP. WILL ACCEPT REASONABLE OFFERS
Shouldahadav8 is offline
