Old 08-22-2011, 10:41 AM   #1
jacobcartmill
jacobcartmill is an unknown quantity at this point
WTT/WTS: 92 coupe RB26DETT ?
hey guys,
i don't post here much (mostly SEARCH and lurk alot).
anyway, I bought an unfinished s13 coupe project from a local guy here in TN that already had an RB26DETT in it. Apparently the guy who had it really didn't know his way around wiring, and basically I had to rewire the whole car. Anyways, on to the details:
R33 RB26DETT (R33 had longer crank snout to fix the oil pump drive problem the R32s had)
RB25 oil pan and custom pickup (very nicely done)
trans (was opened up, inspected, and re-sealed, shifts 100% perfectly, smoothest trans i've ever had)
MINES ECU
NEW NISMO r33 gts-t clutch
R33 GTS-T diff
Mckinney mounts (High $$$)
Mckinney downpipe (High $$$)
Custom FMIC
Blindside driveshaft
Innovate wideband
Coolant temp and boost gauge
Rebuilt z32 26mm Calipers
New brake master cylinder
Flushed all fluid
New rotors
EMUSA Coilovers
Brand new steering rack
Tein tension rods
Newish windshield
Functional headlights
350z 17" wheels and good tires.
I also removed/flushed/cleaned/reinstalled the gas tank
Battery relocated to trunk with high quality welding cable (way better than normal battery cable) and nice crimp fittings, all plastics in trunk.
I remade most of the harness (i'm mostly a wiring guy) and got it running beautifully on a R32GTR ecu, and i'm considering trading it for an S14, or maybe something else that is just newer and has AC (this is my DD at the moment)
Body:
The car is a white 92 Coupe Sharknose with decent paint, over-fenders, black pignose carpet (very clean), S14 seats, digital cluster (cant get it to light up at the moment) with an I30 tach, etc. the shell isn't the best, and it could use a paintjob, but it has ZERO rust on it..
I basically bought this unfinished project from a local guy, went through the whole car, finished it, and now i want something a little NICER and maybe not quite as rowdy. i just wanted to throw this up on here and see what kind of trade i could get, or maybe even how much you all think it is worth to sell it outright. i can post pictures if anyone is interested.
(edited to make this a little easier to read. see update and price further down)
jacobcartmill is offline
coupe, rb26, rb26dett, s13, trade
