Old 11-20-2003, 08:50 AM   #1
mixxamike
mixxamike's Avatar
mixxamike is an unknown quantity at this point
'91 cams...again...
I'm a bit confused as to what part of the '91 camshafts I need to put into my car. I was first under the impression that I needed the entire camshaft (cam gear at end, and the camshaft itself with lobes and all). However, when trying to buy these '91 cams, I was told by the seller that all the camshafts in every DOHC 240sx are the same and the only thing that is different about the '91s are the gears. Do I need to change just the cam gears or the camshafts as well?
I always thought it was the lobes on the camshafts that determined the durration (240/248 on '91s) not the cam gears. Could someone please straighten me out?
-Mike
mixxamike is offline   Reply With Quote
Old 11-20-2003, 02:25 PM   #2
mixxamike
mixxamike's Avatar
anymore replies? anyone? I'd like a few more opinions.
Old 11-20-2003, 02:49 PM   #3
orion::S14
orion::S14's Avatar
orion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud oforion::S14 has much to be proud of
Whoever told you that the cams were the same for all the DOHCs is a dumbass, or at least uninformed.
You need the cams. Period.
All the cam gears are identical...so those DO NOT matter.
'91-92 cams are the good ones, 240 intake duration, 248 exhaust duration...as opposed to 232/232 for '94 and all S14s.
- Brian
orion::S14 is offline   Reply With Quote
Old 11-20-2003, 04:47 PM   #4
mixxamike
mixxamike's Avatar
Hey, thanks for the input guys. You just confirmed what I thought to be correct. I guess I'll continue searching for some '91 camshafts.
Old 11-20-2003, 07:06 PM   #5
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
how much are you looking spend?..a friend has a set here he doesn't need anymore..
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 11-20-2003, 08:07 PM   #6
mixxamike
mixxamike's Avatar
I was actually going to just go to the local you-pull-it junk yard and rip them off the 240 they have there. I know I can get a hell of a deal there. Thanks for the offer though.
Old 11-21-2003, 04:47 PM   #7
1993240
1993240 is an unknown quantity at this point
"'91-92 cams are the good ones, 240 intake duration, 248 exhaust duration...as opposed to 232/232 for '94 and all S14s."
So what kind do the 1993 s13 have?
1993240 is offline   Reply With Quote
