Old 09-01-2011, 09:57 PM   #1
homestar240
homestar240's Avatar
homestar240 is an unknown quantity at this point
Bucking at 3-4k help
95' 240
My KA starts bucking violently when i hit around 3k. the tach needle goes crazy between like 3-3.5k when it starts doing it, and the whole car starts bucking back and forth. changed plugs, wires, cap, rotor, fuel filter. also has a new distributor, correctly timed.
homestar240 is offline   Reply With Quote
Old 09-01-2011, 10:43 PM   #2
Jay420sx
Jay420sx is an unknown quantity at this point
Fuel pump...?
Jay420sx is offline   Reply With Quote
Old 09-01-2011, 11:06 PM   #3
homestar240
i was thinking fuel too....i wasn't sure if it was the pump or maybe a leaking injector? i can here the fuel pump prime and cut off...
Old 09-01-2011, 11:09 PM   #4
Jay420sx
Yea but its prob weak as hell. If you have a friend with a 240 use their fp to see if it gets better.
Old 09-01-2011, 11:16 PM   #5
homestar240
thanks for the help
i'm probably going to try and change it anyways i'm sure it could use it.
Old 02-09-2012, 05:35 PM   #6
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
any update?
Kaifd3s is offline   Reply With Quote
Old 02-09-2012, 06:33 PM   #7
SMM
Trader Rating: (26)
SMM is an unknown quantity at this point
Feedback Score: 26 reviews
Mine did the same.
Fuel pump. Change the sock also can be clogged.
Check MAF connection. Car will also do this if the MAF is unplugged car goes into limp mode.
SMM is offline   Reply With Quote
Old 02-11-2012, 02:24 AM   #8
nautical miles
nautical miles is an unknown quantity at this point
had a similar issue, did all of the steps you will find if you search for this issue (which is fairly common). brand new fpr, new injectors, new iacv, new fuel filter, changed plugs, wires, cleaned the maf, checked codes over and over. never had one. eventually went to an autoparts store that i frequent all the time and told the guy that i was going to buy a new maf but if it didn't fix my problem, could i bring it back? he said that it would have to be a "wrong part" in order to do that. so i paid the 280.00 some odd dollars walked out to the parking lot, swapped mafs and it fixed every issue i was having. then returned the core. so if you have a good friend at a parts store maybe he will let you try it without buying it. other wise if it doesn't fix it, return it for a "wrong part".
Originally Posted by tengo240 View Post
Originally Posted by juan3023 View Post
how much does a container usually goes for does any one on here have any idea ?
Not sure exactly what they go for but i would assume a premium if its a week before race wars.
nautical miles is offline   Reply With Quote
Old 02-11-2012, 02:39 AM   #9
TheSquidd
TheSquidd's Avatar
Had something similar going on with my SR.
Cleaned the MAF. Runs tits now.
TheSquidd is offline   Reply With Quote
Old 02-11-2012, 02:55 AM   #10
s13 @ fullboost
s13 @ fullboost's Avatar
s13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfections13 @ fullboost is close to perfection
Make Sure maf is clean use maf cleaner to clean it. Check wires for breaks make sure not are touching and put a little dielectric grease on the pins should solve your issues unless maf itself is busted inside
Old 02-11-2012, 07:06 AM   #11
silvia_s14
silvia_s14 is on the path to ruinsilvia_s14 is on the path to ruinsilvia_s14 is on the path to ruin
Send a message via Yahoo to silvia_s14
Had same problem. Changed injectors, fuel pump, fuel filter then swapped mafs with my bro and car ran perfect again. I got a used one on here from another zilvian. Car is still running good
silvia_s14 is offline   Reply With Quote
