Old 09-03-2011, 09:20 AM   #1
NickIsAZero
Trader Rating: (41)
NickIsAZero is an unknown quantity at this point
Feedback Score: 41 reviews
s13 1989 Nissan 240SX - RB20DET - R32 - 5lug $3000
SOLD!
I've decided to sell this car because I'm starting a new job next week and don't have time to finish this project up. Has 82,768 miles on the vehicle and it reads on the gauge cluster. I went through the car and began re-wiring the engine harness and tucking it out of sight. It's basically all complete now, minus the lower harness ($92 from Wiring Specialties). My loss is your gain on this project! Asking $3000 as the car sits on Tenzo lowering springs & no driver's seat.
Exterior:
Clean body, only a couple minor dings that are visible in pictures.
Factory front lip
JDM signal lights
R32 Skyline rims
Interior:
Working digital speedo with working HUD
Crackless dash
Greddy shift knob
Suspension/Brakes:
Tenzo R lowering springs
KYB GR2 struts
R32 Skyline 4 piston front brake calipers & 30mm rotors
5 lug swapped front & rear
Circuit Sports front & rear stainless brake lines
Engine/Transmission:
R32 Skyline RB20DET engine/transmission swap
McKinney motor & transmission mounts
RB25DET ball bearing turbo
3" downpipe & mid-pipe exhaust (turns down at gas tank)
Walbro 255 fuel pump
Front mount intercooler & piping
12" electric cooling fan
3" core aluminum radiator
Battery relocated to trunk
VLSD
I will include a RB20DET a/c compressor & power steering reservoir also.
As I stated before, my asking price is $3000. No I will not part the car out, no I will not fix it and then bring it to you. Clean title & keys in hand!
ISIS coilovers - $500
Sparco Sprint seat with rails/brackets - $250
NickIsAZero is offline   Reply With Quote
Old 09-03-2011, 10:46 AM   #2
drifter1000
drifter1000 is a well-known jackass
Send a message via AIM to drifter1000
super super CLEAN.
BUMP!!!!!!
drifter1000 is offline   Reply With Quote
Old 09-03-2011, 11:23 AM   #3
da_crew10
da_crew10's Avatar
da_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond reputeda_crew10 has a reputation beyond repute
Any mechanical problems? I'm guessing no power steering?
da_crew10 is offline   Reply With Quote
Old 09-03-2011, 12:20 PM   #4
subiesean
subiesean's Avatar
subiesean is an unknown quantity at this point
this is a pretty good deal how many miles on the motor tranny???
I change cars too often...
Ho.Mo.Co.
subiesean is offline   Reply With Quote
Old 09-03-2011, 01:03 PM   #5
EnvyS13
EnvyS13 is an unknown quantity at this point
as it sits right now, is it driveable?
EnvyS13 is offline   Reply With Quote
Old 09-04-2011, 11:26 AM   #6
NickIsAZero
Trader Rating: (41)
Power steering pump, rack and lines are in the car. I have a s-chassis & R32 resevoir in the trunk that needs to be connected to the lines.
To be honest I do not know the mileage on the motor/trans. I was told by the previous owner that the timing belt & water pump were recently replaced.
As stated the car needs a transmission harness, there for it does not run. I can give the car power to show you that the motor does crank over, power to the dash/hud and everything. I've personally driven this car, pulled it into my shop and began to fix all the issues. Now I just don't have the time to complete it and need the room.
