Old 09-11-2011, 08:11 PM   #1
andyv316
andyv316 is an unknown quantity at this point
96 headlight problem---240sx
So i wired in a relay for my fans and all of sudden i noticed i dont have any power to my passenger side headlight. I check the bulbs and they are fine, i even plugged them into my driver side and they work fine. When I wired the relay in i didnt jump and powers or grounds. I ran the power for the relay off the cigarette lighter in the car, I did this bc i took all my gauges out since im n/a now, and i had a wire preran out into the engine bay.
I checked the wiring i could see before it went back into the harness and nothing looks burnt or anything. All the fuses are good, being that the s14 has the same fuse for both sides. Also switched out the headlight switch in the column.
Any help would be appreciated.
I did search but the only thing i could find was s13 stuff.
andyv316 is offline   Reply With Quote
