ft 1989 cressida drift ready
up for trade only is my 1jz powered x8 cressida. i love the car but i want a s chasis again or something like a fc or supra. the car runs cherry just has some body damage that is easily fixable ijust dont car to fix it as this is a drift car. the chasis has 215,xxx on it and drives pretty good. i have clean title in hand free of leans and no salvage. i prefer trade but you can off er cash if you want. the car is in new mexico
if interested call or text 505-515-8977 im in the middle of moving so i have limited access to a computer mods/stuff jz70 1jzgte fresh rebuilt stock injectors(bumped up 10cc from rc engineering) aeromotive fuel pressure reg and filter new oil pan excessive manufacturing engine brackets excessive manufacturing poly motor mounts tread stone inter-cooler tread stone ic piping aftermarket piping off the turbos Hks b.o.v Koyo radiator w 58 transmission (freshly re sealed) with bell housing adapter drift motion flywheel lock ring drift motion tranny to motor bolt kit arp flywheel bolts new 2jz flywheel center force 6 puck clutch drift motion power steering conversion line new 2jz map sensor greddy turbo timer bee r revlimiter hks fuel cut defender excessive manufacturing steering knuckles excessive manufacturing tie rod extensions megan track coilovers welded diff boost, water temp, and oil pressure gauges welded diff one off home made exhaust with presilencer and race cat ect. comes with trade depending 16x8 -10 front 16x11 ? rear mitsubishi starion wheels, or supra saw blades, or 300zx wheels, or stealies pics up soon with paint or text for pics ![]() ![]() ![]() ![]() ![]() ![]() ![]() mor pics as per asked call me for fastest response 505-515-8977 Last edited by 89fastback; 09-16-2011 at 09:49 PM.. |
#7 |
Would you be interested in an 03 r6? GPR stabilizer, 520 chain kit, power commander, flush mount turn signals, rear integrated tail light/turn signals, 8k hids, full termignoni exhaust shortened $1100 sounds amazing. Just did full tune up including new spark plugs, oil change, cleaned and reoiled k&n filter, and replaced all 4 coil packs with newer ones and did a smog delete. Pm if interested
