Old 09-17-2011, 04:22 AM   #1
lovin1ife
lovin1ife's Avatar
lovin1ife is an unknown quantity at this point
FS/FT::91 turbo, gen3, lsd, pte 5857 turbo, fully loaded
I'm not in hurry to sell, and will consider trades. Seeing if i can get what i want for it. Asking price with all modifications is 16k, can lower price to 10.5k. Please do not make me any ridiculous offers or post any unwanted comments. Thank you in advance.
I have poured countless hours of labor and sweat into this car. Built by yours truly. I have worked on numerous mr2s and have owned many dueces. I can have people vouch for my work if needed. This is a car where you can just turn the key and drive.
Car is solid, handling is planted and stable and everything works as how it is supposed to. Turns head when you want to, gets compliments everywhere. A blast to drive. Sounds like a highly modified beast when gas is applied liberally. Starts up in a heart beat, no oil leaks, no transmission grinds, shifts smoothly, runs fine, no overheating, no cels, zip. Daily driven as commuter car. Currently pushing 280+/-whp, @ 14psi untuned on stock ecu(supporting mods are capable of 330-370whp if tuned on 91 octane. All engine mods are out of sight. Can throw in powerfc + datalogit and meth kit to tune for an additional $1300. Has almost every tasteful mod i can think of. Fully converted to 93 suspension, almost full 1994 exterior conversion. Perfect for daily driving or for track racing, drift, show car or what have you, it can do all of the above.
Some facts and functions:
5 speed
power windows
power mirror
rear window defroster
air conditioning
Sunroof
CLEAN title
straight frame
original paint
13x,xxx miles on chassis
61k on motor
~8k on most aftermarket/maintenance parts.
additional add-on functions
built in bluetooth
dvd player
voice command
built in gps
remote start
remote trunk popper
remote turbo timer
ipod capability, usb, sd card input
in cabin boost controller
Safety harness
1 mile range alarm
Lojack
steering wheel lock
keyless entry
Modifications: The car consists of mods valuing $17590+ not including labor and time spent on car such as wire tucks, fender rolling, installation of parts and more. Most of these mods will sell easily if parted out. Most mods have less than 8k miles on them except motor and stuff. I have a folder of receipts for almost everything. I have included a rough resale price on all the following mods.
Engine
JDM 96 gen3 3sgte w/ 55k miles 2500
-Traction control function (missing ecu)
Clutch masters Stage 3 clutch(fx300), stock pedal while gripping hard 450
JDM LSD 1996 turbo transmission 700
Berk dual 3” exhaust system 550
EMSPOWERED Precision 5857 turbo kit 2300
-Precision 5857 turbo with billet compressor wheel .63 a/r
-Tial v-band MV-S 38mm external dump wastegate
-Custom made 3” v-band downpipe w/ wideband + o2 sensor port
-Stainless steel braided oil feed line
-Custom one piece oil return system
-Custom machine made oil fittings
-Custom heatshield to cover everything out of sight
ATS upgraded LSD axles 350
Fidanza light weight flywheel 170
Apexi intake 120
Walbro 255lp fuel pump w/ install kit 85
Innovative wideband 150
TRD left and right motor mount 130
Interior
Recaro evo 9 seats w/ rails 1300
blitz sbc id boost controller 450
Momo steering wheel 180
Trd ball shift knob 40
Leather door panels 250
Viper 1 mile range 5901 2 way w/ remote start alarm 200
93 shifter 30
Aluminum solid shifter base bushings 20
Turbo timer switch 3
remote start activate/deactivate switch 3
NRG short hub 105
WORKS bell quick release lock 130
NRG quick release 110
kenji/emspowered harness bar 250
sparco harnesses 140
Audio
Pioneer AVIC BT910 touchscreen headunit 400
-Built in Bluetooth
-Built in GPS
-Divx video playback
-Casual voice command
-IPOD interface
-SD card input
-USB input
-Flashed to firmware 3.0
boston mb quarts front speakers - a lot..
boston mb quarts rear speakers - a lot.
Kenwood 9105D 900rms watt amp 170
emspowered / Dayton 10” subwoofer 600watt RMS @ 4 ohms. 130
Custom 10” subwoofer box 60
Suspension
H and r coilovers 950 (one of the most comfortable coilovers available for street)
93 turbo 2 piston brake system 350
Trd front and rear sway bars 350
93 endlinks front and rear 80
93 rear suspension crossmember 50
93 rear trailing arm 50
New tie rods 60
New Ball joints 60
SS brake lines 100
ATS racing Master cylinder brake brace 120
Twosrus sway bar reinforcement plates 65
Ultra racing 3 point front chassis brace 170
Ultra racing 4 point engine bay chassis brace 170
Poly urethane engine mount 80
poly urethane suspension bushings all around 130
Exterior
oem mud flaps 150
94 wing spoiler 200
Greddy front lip 250
Shine auto side skirts 400
Advan racing RG 1 wheels double staggered 2100
-17x7.5 235/40/17(kuhmo ast tires),
-18x9.5 275/35/18(sumitomo htr II)
94 tails 320
94 trunk lock cylinder 60
Lightning
dome light leds - 15
gauge cluster leds - 15
license plate leds – 6
Pegasus projector headlights 200
DDM tuning 35watt 6000k HIDs H7 40
DDM tuning 35 watt 6000k HIDs H3 40
Misc
Engine lid gas prop 50
trunk popper solenoid - 30
CRW spherical shifter cable end 40
Lojack 700
Cons - one hid bulb for foglight is beginning to fail.
missing a microphone for bluetooth feature
passenger fender was replaced to a 93 fender so paint is mismatched
Pros -
trunk is rigged to only open with key or remote fob and not by lever due to theft issues.
maintenance parts are cheap and easy to find
these cars lasts forever
great for those looking to continue a project
Will consider trading for a e46 M3 preferably, e39 M5, a clean mercedes benz or bimmer, G35, 07+ civic si, STI, evo, corvette, IS250, cash
Pics would definitely help.
Asking price with all the modifications - $16000.
I have most original parts if want to lower the price.
some things i can do to lower price to $10700
stock seats (-1200)
stock side skirts (-350)
stock wheels (-1700)
stock radio deck (-400)
no subwoofer and amplifer (-$280)
no harness system (-350)
no hub lock (-130)
no quick release (-100)
no strut front and rear strut braces +brake cylinder brace (-400)
no electronic boost controller (-350)
Parts not installed
Power FC ecu - 1000
datalogit - 300
stock side skirts - 40
93 front lip - 250
93 wheels - 300
91 spoiler - 100
stock seats - 180
stock radio - 80
Videos:
http://www.youtube.com/watch?v=a1QH8TyM90s
http://youtu.be/q2EWb_M4Zzw?hd=1&t=23s (wheel is rubbing badly in this video due to a spacer i slapped on in the rear. Does not rub anymore)
Most recent pictures
Current stance
This is not the current stance of car
Not current stance
Current engine pic
A higher quality shot of the engine bay displaying the cleaniness of everything. This was w/o aftermarket turbo installed
All photos can be found here
mr2 4 sale pictures by bludeathx - Photobucket
lovin1ife is offline   Reply With Quote
Old 09-17-2011, 12:28 PM   #2
Aviator
Aviator is an unknown quantity at this point
Seriously sexy. Free bump for you. Wish this was in my price range.
Aviator is offline   Reply With Quote
Old 09-17-2011, 12:31 PM   #3
FoBoNtHeRuN
FoBoNtHeRuN is an unknown quantity at this point
Send a message via AIM to FoBoNtHeRuN
Beautiful!! GLWS!
FoBoNtHeRuN is offline   Reply With Quote
Old 09-18-2011, 04:56 PM   #4
ZzZleeper
ZzZleeper is an unknown quantity at this point
So clean! Glws
Maybe interested??
http://zilvia.net/f/cars-sale/401709...n-stanced.html
ZzZleeper is offline   Reply With Quote
Old 09-20-2011, 05:09 PM   #5
schendorf
schendorf is an unknown quantity at this point
are you parting out? i would be interested in many parts. message me
schendorf is offline   Reply With Quote
Old 09-20-2011, 07:24 PM   #6
Tooslow1
Tooslow1 is an unknown quantity at this point
Absolutely gorgeous... Makes me miss mine so much more :/
Tooslow1 is offline   Reply With Quote
Old 09-21-2011, 06:17 AM   #7
o0ohaviko0o
o0ohaviko0o is an unknown quantity at this point
Send a message via AIM to o0ohaviko0o Send a message via Yahoo to o0ohaviko0o
How I miss my Mr. 2.
o0ohaviko0o is offline   Reply With Quote
Old 09-22-2011, 02:48 AM   #8
lovin1ife
lovin1ife's Avatar
Thanks everyone for your interest and compliments!
Sorry no part outs as of right now.. Unless car is sold or is crashed... *knock on wood* lol.
I would trade for that beautiful 300zx.. but it would not really do for me.. trying to get out of the car scene and finish up school
