Old 09-20-2011, 10:27 PM   #1
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
Exclamation 100s of OEM Parts from: SR KA DOHC SOHC S13 S14 Z32 Q45
Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843.
Email - [email protected]
Call/Text -
657-377-8I30
Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING. I delete ALL sold parts within 24 hours so if you see it here, its available.
* For instant respond, reply to this thread since it will forward to my cell.
UPDATED on 5/10/22.
All parts and photos are listed on page one.
My other thread:
NEW parts listed
S13 radiator bushings:
top sold
bottom $10 2x, last 2
S13 steering rack brackets - $15 2x
S13 fuse cover - $5
S13 top hats with hardware as shown - $30
S13 Silvia headlights caps/locks - $10 2x
S13 temperature sensors - $20
S13 dohc throttle cable bracket - $5
S13 oil cap - $5
-yellow cap sold
S13 fuel filter bracket - $10
S13 timing tensioner - $20
S13 timing guard - $20
male lighter - $5
S13 chassis rubber plugs - $2 each
S13 vacuum (connects to brake booster) - $5 each
S13 donut lock bolt - $5 each
Differential or transmission plug - $10 each
S13 SR transmission sensor - make offer
S13 radiator bracket - sold
S13 SR throttle body bracket - sold
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 09-20-2011, 10:29 PM   #2
vutony
vutony's Avatar
Stock KA DOHC SOHC Parts
i do SR wiring
Old 09-20-2011, 10:32 PM   #3
vutony
vutony's Avatar
KA auto flywheel bolts (3) - $10
- bolts are in good shape, not stripped
S13 Rear Toe Arm Hardware - $20
Need other hardware, PM me.
I have most hardware for S13 rear end as well.
Axles bolts (complete set) - $40 shipped
Driveshaft bolts (4) - $20 shipped
Diff bolts to subframe (2) - $15 shipped
Diff cover bolts (8) - 20 shipped
Diff fill 1/2" ratchet bolt (1) - $10 shipped
Diff drain - SOLD
Tomei diff gasket - $20 shipped
(used but very little miles and looks new)
S13 diff cover - SOLD
brake reservoir tank - $10
axle hardware - $10
sway bar endlinks - $10 per set (one set sold, two left)
subframe bracket - $10 per set, 2
s13 door openers - $15 both
S13 steering column - $40 top column
- Removed from running cars
- In good shape, threads are intact
i do SR wiring
Old 09-20-2011, 10:32 PM   #4
vutony
vutony's Avatar
s13 rear caliper bolts - $10
engine cross member hardware - $10 per set, one set sold
wheel stopper - $10
i do SR wiring
Old 09-20-2011, 10:33 PM   #5
vutony
vutony's Avatar
i do SR wiring
Old 09-20-2011, 10:34 PM   #6
vutony
vutony's Avatar
Stock SR Parts
Transmission mount to transmission bolts - $5
Transmission bracket to chassis bolts - $10
SR20 5 speed flywheel bolts (8) - $30
- Six 6PT bolts and two 12PT bolts
Nismo radiator cap - $20 ($55 @ frsport.com)
OEM SR headstuds - $40
- In excellent shape
- Has about 5,000 miles on them
SR20 Turbo Oil Return Tube - $20
SR20DET coolant sensors - $20
Pipe and hose - $sold
Crank pulley bolt and washer - $10
S13 SR injector caps, cushion ring spacers and bolts - $30 each set of 4
i do SR wiring
Old 09-20-2011, 10:35 PM   #7
vutony
vutony's Avatar
Stock S14 Z32 Z33 Q45 Parts
S14 Auto Driveshaft - $80
- Removed from a running car
- Center carrier is good shape
S14 Ebrake cables - $30
- Cables are in good shape
350Z G35 Brembo Slotted Rotors Front Set $220 (Purchased new at FR @ $389.95 plus tax)
- In great shape with less than 2,000 miles.
- Has a minor defect from the calipers rubbing on the rotors.
- Its about 30.16mm thick, min thickness is 28.4.
- Rotors are 12.75 in diameter
Z32 Front conversion brackets to use 350Z rotors
I can get these for you if needed $100 extra. The brackets below are sold.
Z32 rear caliper bolts - $10 shipped
Q45 ignitor w/ pigtails - $30
i have the installation if needed
i do SR wiring
Old 09-20-2011, 10:36 PM   #8
vutony
vutony's Avatar
i do SR wiring
Old 09-20-2011, 10:37 PM   #9
vutony
vutony's Avatar
SOLD
Z32 OEM rear brake pads
S13 SR ignitor pigtails
S13 gas tank neck
S13 coupe trunk assembly
Raybestos front pads
S13 center console
S13/S14 rear 4 lug hubs
S13 foward links (traction arms) w/ energy bushings pressed
S13 toe arms w/ energy bushings pressed
S14 rear traction arms
S13 hood latch cable
S13 oem powered mirrors
s13 base model antenna
s13 silvia triple projector housing
Door shells (bare)
rear support
S13 steering column cover
stereo amp "white box"
T25/T28 OEM coolant line
Oil line
sohc and dohc throttle cable
rear hatch speaker brackets
i do SR wiring
Old 09-20-2011, 11:11 PM   #10
Touge_Monster
Touge_Monster's Avatar
Touge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond reputeTouge_Monster has a reputation beyond repute
Originally Posted by vutony View Post
How much for the two rear plastics?
Touge_Monster is offline   Reply With Quote
Old 09-20-2011, 11:20 PM   #11
Dsic240sx
Dsic240sx's Avatar
Dsic240sx is an unknown quantity at this point
Damn you have a bunch of shit i'd like to check out. Can i cruise through your pad and see whats up?
Dsic240sx is offline   Reply With Quote
Old 09-21-2011, 05:49 PM   #12
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
any chance you've got a lock cylinder for an s13 drivers door that works properly? send me a pm or text me 815 508 2202
WTB: 1/24 scale chuki s13 model.
93nismo is offline   Reply With Quote
Old 09-22-2011, 06:15 PM   #13
nissanman22
nissanman22's Avatar
nissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choicesnissanman22 has made poor choices
gas cable mechanism sold to me
yo
nissanman22 is offline   Reply With Quote
Old 09-25-2011, 01:14 AM   #14
eyehate
eyehate's Avatar
eyehate will become famous soon enougheyehate will become famous soon enougheyehate will become famous soon enougheyehate will become famous soon enougheyehate will become famous soon enough
Does the speedo (not HUD one) work on the DOHC digital cluster? How much shipped for both the DOHC and the HUD unit that works shipped to 87109?
DriftExchange
eyehate is offline   Reply With Quote
Old 09-25-2011, 03:08 AM   #15
alohaworld
alohaworld is an unknown quantity at this point
s13 dohc KA distributor. lmk if you have a good one hah.
alohaworld is offline   Reply With Quote
Old 09-28-2011, 10:15 AM   #16
vutony
vutony's Avatar
PM'd
Hahah, done deal. Thanks
Sorry no.
Thanks, done deal.
PM'd
i do SR wiring
Old 09-30-2011, 07:25 AM   #17
ground_shaking
ground_shaking is an unknown quantity at this point
if you still have how much for the hud cluster that the speedo doesnt work shipped to 32708
ground_shaking is offline   Reply With Quote
Old 09-30-2011, 10:17 AM   #18
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
I feel like a dick asking, cause i hate when people ask for parts not listed, but do you have a S13 fuel pump hanger assembly?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 10-03-2011, 08:34 PM   #19
driftjunkieunit
driftjunkieunit is an unknown quantity at this point
Thumbs up Need parts :)
hey mate, just letting you know ive sent you an email from [email protected] regarding some parts
driftjunkieunit is offline   Reply With Quote
Old 10-05-2011, 03:47 PM   #20
driftjunkieunit
Cool Parts sold
The following items sold to me:
S13 Gas Tank Neck
DOHC digital cluster part – the black cover
S13 side mouldings near window
OEM S13/S14/S15 SR20DET O2 Sensor (FAT type)
S13 SR ignitor pigtails only
Thanks!
Old 10-05-2011, 08:54 PM   #21
Andrew40
Andrew40 is an unknown quantity at this point
got a power steering pump for an s 13?
Andrew40 is offline   Reply With Quote
Old 10-09-2011, 10:44 AM   #22
vutony
vutony's Avatar
PM sent lmk
Sorry no
S13 Gas Tank Neck
Thanks!
No thank you.
Yes for SR, http://zilvia.net/f/sale-items/40039...ngle-part.html
i do SR wiring
Old 10-09-2011, 10:59 AM   #23
eli-s13
eli-s13's Avatar
eli-s13 is an unknown quantity at this point
Still have a Chilton repair manuals? And the Hud cluster cover? Any scratches on it?
eli-s13 is offline   Reply With Quote
Old 10-10-2011, 06:02 AM   #24
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
Coupe latchey latch sold to me,
plus a knock sensor.
Thanks, Vutony!
nissanfreak317 is offline   Reply With Quote
Old 10-10-2011, 08:56 PM   #25
rastaman
rastaman is an unknown quantity at this point
z32 caliper rebuild kit and hood latch and cable ship to 32907?
rastaman is offline   Reply With Quote
Old 10-14-2011, 10:17 AM   #26
vutony
vutony's Avatar
Yes and sold to you, thanks.
Thanks, Vutony!
NP, its on the way.
Kit is sold. I have the other two items.
LMK
i do SR wiring
Old 10-18-2011, 07:26 AM   #27
JdmDrift4Food
JdmDrift4Food's Avatar
JdmDrift4Food is an unknown quantity at this point
Ship Pignose? Lmk!
JdmDrift4Food is offline   Reply With Quote
Old 10-18-2011, 01:01 PM   #28
PANDAemic
PANDAemic is on a distinguished road
Still have the S13 Center Console?
PM me your address, I'm close by.
PANDAemic is offline   Reply With Quote
Old 10-18-2011, 01:44 PM   #29
Nismo_Chris
Nismo_Chris is an unknown quantity at this point
Ill take the front used brake pads. just let me know how much shipped to florida 32504
thanks yo
Nismo_Chris is offline   Reply With Quote
Old 10-18-2011, 02:04 PM   #30
nismoracingsx
nismoracingsx's Avatar
Trader Rating: (32)
nismoracingsx is an unknown quantity at this point
Feedback Score: 32 reviews
Looking for a base model s13 steering wheel...
Shipped to 31405
nismoracingsx is offline   Reply With Quote
