Old 12-01-2003, 12:17 AM   #1
holisticbeatz
holisticbeatz's Avatar
holisticbeatz is a well-known jackass
s14 Fuel pump sensor problem!!
I went to Drift Day 10 with my S14. I got there and my gas tank read a little above a quarter tank. So I decided to put in $10.00 worth of gas before heading to the track. After pumping, the gas gauge read a little above 3/4 full.
After making a few hard runs on the track, I noticed my gas gauge was reading full as I made my way back to the pit area. I thought nothing of it and let my car cool down. An hour later, I made a few more runs and afterwards, the gas gauge still read full. Now I become a little worried, I have a heavy right foot and I know I burned up at least a 1/4 tank on the skidpad.
At the end of the day, I decide to go to the gas station again and fill up my tank. This time I decided to fill it all the way up. As I was pumping, the gas pump handle stopped at 7 gallons of gas sold. I thought that this would correct the problem and the fuel pump sensor (floating thingie inside the tank) would get straight and start to function properly again. I drove all the way home and still the gas gauge read full. I drove all day today and still the gas gauge is reading full.
Now I don't know what to do. My friend said that the fuel pump sensor thing might still be stuck. So tomorrow morning, I will have to open up the trunk and remove the plate covering the fuel pump inside the gas tank. I'm not sure what to look for, so if anyone here has any experience with something similiar to what I'm going through, your input will be greatly appreciated.
-kenny
Trust and I don't mean GReddy.
holisticbeatz is offline   Reply With Quote
Old 12-01-2003, 09:54 AM   #2
Ranger_Man
Ranger_Man is an unknown quantity at this point
Send a message via AIM to Ranger_Man
before you go rip roaring in there you will either want to wait a week and drive your car during that time to get the gas out or drain it another way.
heres what most likely has happened, as it happened to me.
in the s14 gas tank there is a big plastic tube. iirc that is our device that measures how much gas is in there. all you have to do is slide it back onto the two brackets it sits on. however, to see the brackets you need to have a 1/4 tank or less. its a real easy job to do. fyi, the brackets are on the front passenger side of the tank, so go at it through the trunk.
Ranger_Man is offline   Reply With Quote
