Old 09-22-2011, 02:31 PM   #1
HellaSexyS13
HellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-knownHellaSexyS13 is making his/her stupidity well-known
help, sr20 wont start
so im done with my s14 sr20 swap and i turn the key and the motor turns over but it wont start. the fuel pump is not priming or pumping so that has to be the probelm,
the fuel pump fuse is still good
not sure how to check to see if the egi relays (for fuel pump) are good or not
what could the problem be
HellaSexyS13 is offline   Reply With Quote
Old 09-22-2011, 05:33 PM   #2
HellaSexyS13
so none of the relays in the passenger side fuse box are getting any power, or the fuse box in general. also the 75a ALT fuse was blown, this shouldnt have an effect on the box getting power
Old 09-22-2011, 10:36 PM   #3
nissansrdub
nissansrdub's Avatar
nissansrdub is an unknown quantity at this point
check to see if your getting power to the fuel pump with a DMM. if your getting power bad fuel pump. if your not getting power back track and find out where it stops with the wire schematic.
nissansrdub is offline   Reply With Quote
Old 09-22-2011, 10:59 PM   #4
DeeezwasRiceSauce
DeeezwasRiceSauce is an unknown quantity at this point
clutch.. pump your brakes.. start the car with the brakes held. i usually don't start my car with the brakes but i have a separate source to turnover the fuel pump separately.. and the brakes drain your alternator... or you need a ecu reset.. to reopen the fuel map if you burnt oil before you park
DeeezwasRiceSauce is offline   Reply With Quote
Old 09-23-2011, 05:27 AM   #5
HellaSexyS13
well the egi and egi pump relays are not clicking when i turn the key to acc, so that is where the problem is i assume, the fuel pump is brand new too
Old 09-23-2011, 12:57 PM   #6
HellaSexyS13
using a multimeter, i removed the two egi relays and with the key on i put the red poker or whatever you wanna call it in the plug and the black on a ground screw and they both show power, would this mean its just the relays being dead or what?
Old 09-23-2011, 04:36 PM   #7
clivey
Trader Rating: (-1)
clivey is an unknown quantity at this point
Feedback Score: -1 reviews
sr20 swap in your s14 you say?
what was in there before? i went from a kouki n/a sr to sr20det and had to get a power to the ecu first (thats why my fuel pump wasnt priming...) and then had to get a supply to the coilpacks think its similar for a sr into a ka s14 swap
hope this helps, clive
clivey is offline   Reply With Quote
Old 09-23-2011, 04:43 PM   #8
HellaSexyS13
in a s14 sr into a s13, had a ka in there, the ecu has a red light that turns on when i turn the key, the relays in the drivers side fuse box click but not the ones in the passenger side box
Old 02-13-2012, 05:50 PM   #9
zenk!240
zenk!240 is an unknown quantity at this point
im haven the same problem but im not getting any power window locks heat fuel nothing someone help
zenk!240 is offline   Reply With Quote
Old 02-21-2012, 04:26 AM   #10
riptor
riptor is an unknown quantity at this point
check all fuses...bro. i had the same problem....but mine was mostly self inflicted..lol.(hooked batt up backwards)
riptor is offline   Reply With Quote
Old 02-27-2012, 03:27 PM   #11
HellaSexyS13
ecu was bad and the timing was off also, now she runs
