Old 12-02-2003, 09:33 PM   #1
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
Question about clutch
Well my 9 240sx with KA24de motor has about 110k miles on it. I dont think it has ever had the clutch changed and at times i can feel it slip... i was wondering if i had to buy a whole clutch kit, or can i just replace the clutch disk??
dct223 is offline   Reply With Quote
Old 12-02-2003, 10:18 PM   #2
Evil S14
Evil S14 is an unknown quantity at this point
Send a message via AIM to Evil S14
if its gone over 100k miles on the factory clutch, i would suggest getting a whole kit, the TO bearing is probably in need of a change and the pressure plate is probably looking pretty rough
*image exceeds forum limit*
-Moderation
Evil S14 is offline   Reply With Quote
Old 12-02-2003, 11:47 PM   #3
Flybert
Flybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfectionFlybert is close to perfection
Don't forget the pilot bushing and to grease your transmission input shaft.
Flybert is offline   Reply With Quote
Old 12-03-2003, 11:55 AM   #4
96s14kat
96s14kat is an unknown quantity at this point
Send a message via AIM to 96s14kat
most all clutch kits come w/ everything you need, to bearing, alignment tool, pressure plate etc.
96s14kat is offline   Reply With Quote
Old 12-03-2003, 12:08 PM   #5
thelinja
thelinja's Avatar
thelinja is making a name for him/her selfthelinja is making a name for him/her self
If you order your clutch from Courtesy Nissan you'll spend about $170 on parts. That includes TOB, Pilot Bushing, Pressure Plate, and disk. That's if you simply wanna get an OEM replacement. You should also consider resurfacing your flywheel when you take it off to replace the pilot bushing. Replacing the flywheel bolts is another recommendation as well. You don't have to order the alignment tool from the dealer though, it's $5 cheaper if you go to Autozone or AAP and get one.
thelinja is offline   Reply With Quote
