Old 10-08-2011, 07:55 PM   #1
quach
quach is an unknown quantity at this point
z32 help: Nothing works when ignition switch is turned to "ON/ACC"
My 1990 300zx Twin Turbo is having issues with the ignition switch. When I turn my key to "on/acc" no dash lights turn on and of course my car will not start, it doesnt make a noise when I turn the key. My headlights/dome lights/alarm still work and it still makes the chime sound when my door is open. I initially thought it was the security system, but after tracing everything down I'm suspecting it's an ECU issue or a blown fuse somewhere. Is there a fuse for the ECU somewhere that I'm not aware of? Maybe a broken ignition switch?
This all happened after I had my car valeted last night. I turned off my turbo timer so I wouldn't confuse the valet, and when I went to pick up my car after dinner the valet came back and told me "your car isnt starting". I have a feeling it has something to do with the turbo timer that blew something. I uninstalled the turbo timer and still nothing works.
My car is all stock 1990 TT manual and is all stock except an HKS type 0 turbo timer.
Any help would be appreciated! Thanks!
quach is offline   Reply With Quote
Old 10-08-2011, 08:58 PM   #2
S13_240ZX
S13_240ZX is an unknown quantity at this point
Check the Clutch "Jelly Bean".
When you push down on the pedal it hits a switch to start the car.
You can hold it with your finger and turn the key
S13_240ZX is offline   Reply With Quote
Old 10-08-2011, 09:14 PM   #3
quach
Gave that a try, but unfortunately it wasn't the case. None of my dash lights are coming on and my radio, windows, etc arent getting any power and I assume my starter/coils aren't getting any power either.
Old 10-08-2011, 09:43 PM   #4
thizzen4
Trader Rating: (22)
thizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymorethizzen4 is not welcome here anymore
Feedback Score: 22 reviews
check alt fuse under hood or wires under ignition
thizzen4 is offline   Reply With Quote
