![]() Join Date: Dec 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 10 reviews
![]() History on motor: The motor was already running and perfectly fine in the hatch.. Decided to build a coupe so transfer everything out of the hatch and put it in the coupe.
Motor info: Redtop Bolts on upgrades. Apexi Neo Good tune Z32 MAF Like i said.. this swap was already running in the hatch PERFECTLY so it doesnt have anything to do with the tune or upgraded parts on the motor. I go to crank the car after install in the coupe.. it turns over. Gets fuel. NO SPARK. Things Ive already checked: Ignitor- switched it out, nothing changed. Power probe the coilpack connectors- getting ground, no constant power and no signal. Coilpack harness grounded. ECU- gets power. No codes. All fuses and ignition relays replaced and/or appear to be good. Fuel pump is priming and all injectors are working. Motor has 5 solid grounds Battery has 3 soild grounds. Let meknow if you have any ideas or advise. Thanks Carina
