Old 12-07-2003, 05:05 PM   #1
L.D. 100
L.D. 100 is an unknown quantity at this point
I got some rims but i cant find the specs, please help
I ran across some nice rims, theyre Racing Dynamics RGS road wheels, 17x8 up front and 17x9 rear but i wanna know the offset and if i can use them on an s13 with yashio factory wide fenders and keep in mind that i will need to use spacer/adapters for this bolt pattern, im not sure if its 5x120mm or 5x112...so wheel pros can you help? i pretty much need to find out so that i either sell them or keep and use them.
thanks in advance
L.D. 100 is offline   Reply With Quote
Old 12-07-2003, 07:56 PM   #2
Mikes14240sx
Mikes14240sx is an unknown quantity at this point
Send a message via AIM to Mikes14240sx
http://www.tirerack.com/wheels/tech/wheeltech.htm
How much negative camber do you plan to run? How wide are the wide fenders?
Post back when you find the offset.
Mikes14240sx is offline   Reply With Quote
Old 12-07-2003, 08:06 PM   #3
Heartwork
Heartwork's Avatar
Heartwork is an unknown quantity at this point
aren't Racing Dynamics a BMW catered brand?
if it is, the BMW lug pattern is different
Heartwork is offline   Reply With Quote
Old 12-07-2003, 08:13 PM   #4
ridebmx
ridebmx is an unknown quantity at this point
Send a message via ICQ to ridebmx Send a message via AIM to ridebmx Send a message via Yahoo to ridebmx
[quote]keep in mind that i will need to use spacer/adapters for this bolt pattern, im not sure if its 5x120mm or 5x112...[quote]
I like my car, you may not...You like your car, I may not...To each there own, right?
waiting for the sunken look to be cool..lol
ridebmx is offline   Reply With Quote
Old 12-07-2003, 08:17 PM   #5
omen2853
omen2853's Avatar
omen2853 is an unknown quantity at this point
most BMW patterns are 5x120
omen2853 is offline   Reply With Quote
Old 12-07-2003, 09:28 PM   #6
ridebmx
mercedes and audi are usually 5x112
Old 12-07-2003, 09:43 PM   #7
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
mbmbmb23 is on the path to ruinmbmbmb23 is on the path to ruin
Conversion spacers/adapters can be had for $50 each at:
http://performancewheel.com/
(Im not affiliated in any way with that place)
-m
400x200
mbmbmb23 is offline   Reply With Quote
Old 12-07-2003, 10:18 PM   #8
L.D. 100
ok guys i think i might have the offsets, theres little numers on the rims that read 8Jx17H2-ET38 on fronts and 9Jx17H2-ET46 rear. would the last numbers be the offsets? (38 and 46) im basically clueless on these rims, they were basically given to me but i need to figure out if i can use them. they would also have to clear tien HE's
as for negative camber i think id be willing to go down to 4, but im not sure, i havent had negaive camber yet so i cant exactly say what is the max id go
Old 12-07-2003, 10:30 PM   #9
Vopt
Vopt is an unknown quantity at this point
Your so clueless I dunno if I should laugh or cry.
Vopt is offline   Reply With Quote
Old 12-07-2003, 10:41 PM   #10
L.D. 100
man you can laugh so hard itll make you cry, it dont matter to me, just help me out when youre done, if i knew i wouldnt be here asking
Old 12-07-2003, 10:43 PM   #11
SilviaDriver
SilviaDriver's Avatar
SilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enoughSilviaDriver will become famous soon enough
Send a message via AIM to SilviaDriver
http://www.tirerack.com/wheels/tech/offset.htm
go there specifically, read and start measuring. dont be lazy
SilviaDriver is offline   Reply With Quote
Old 12-07-2003, 11:35 PM   #12
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Please say you have an S14?? Other wise those fronts probably wont fit with that spacer/adapter (if you need one). Have you tried bolting up a wheel yet to see if they are 5x114.3 or 5.120? If they are 5x120 you can either *try* a spacer from that link I provided (as skinny as possible), or you can attempt to slightly elongate the lug holes in the rim (and make them shaped like a jelly bean..long and round). That is risky tho...cause you want the wheel to be centered on the hub so it doesnt vibrate at high speeds. If they are 5x120, your best bet may be re-selling these on ebay and getting something else??
-m
400x200
Old 12-07-2003, 11:44 PM   #13
L.D. 100
hahaha i got them free, im not losing anything, but i kinda like them so i was going to keep them.
so even with wide fenders they wont fit? (on s13) 40mm wider front 50mm rear
Old 12-08-2003, 12:35 AM   #14
mbmbmb23
Zilvia Contributor
mbmbmb23's Avatar
Hmm...wide fenders....missed that part. I would give them a shot then. A nine inch rear with 46 offset...thats nuts.....good luck tho.
-m
400x200
