Coolant hose by-pass
I'm trying by-pass some coolant hoses on a S14 Sr20 under the intake manifold just don't know which ones to eliminate any help is appreciated!
![]() Join Date: Jan 2007
![]() Feedback Score: 8 reviews
Oh wow, those are much different. I can start MFG them if you want to send those to me. We are going to start producing our kits in black silicone with our logo on them soon. Same quality as Samco. Let me know if you want to send over those S14 hoses and we will make those as well.
#3 | |
Boostedkouki, you just connect the three main lines that tee off that Y-shapped hardline fitting. The 5/8" line is already connected so you can see where it goes, the bottom of the Y should be 3/4" and you loop it to the 3/4" port above the 5/8", and I assume on the S14 SR the big 1" hose goes to the intake manifold.
You may plug off everything else, that is, if you do not wish to keep the heater and such. If anyone has one of those S14 Y-hardlines for sale, I will buy it, because it looks much easier to use for simplifying the lines as opposed to the S13 one. Unless Mr. om3ga makes the delete hose, which would be wonderful. ![]() Quote:
I have been searching for a simple solution to connect these three ports, and a molded E-shaped silicone/rubber hose that connects all three would definitely be the simplest and neatest. Unfortunately, every place I contacted was only willing to make them in bulk, so I gave up on it for now. ![]() Last edited by Matej; 06-22-2012 at 05:08 PM.. |
