Old 11-28-2011, 05:55 PM   #1
Knapik
Knapik's Avatar
Trader Rating: (36)
Knapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to allKnapik is a name known to all
Feedback Score: 36 reviews
CA Cleaning out Garage! SR/KA/S13/S14 SELL IT ALL!!
Hey guys,
ive got a LOT of parts for sale.
all parts are located in Westminster CA 92683
Email: [email protected]
S14 SE Front and Rear Sway Bars: $20 each
S14 power steering rack: $60
S14 KA down pipe: $25
S14 brake booster: $10
S14 cruise control cable: $10
S14 SR cast iron turbo manifold: $50
S14 throttle pedal: $10
S14 driver side interior handle: $15
S14 passengerairbag: $40
S14 oem tie rods: $20
S14 oem tension rods: $20
S14 axels: $50 each
Random pullies: $5 each
S14 KA heat shield: $10
S14 A/C core: $20
S14 windows with no cracks: $30 each
Brand New S14 SR valve cover: SOLD
S14 steering wheel: $10
S14 steering wheel airbag: $20
S14 Silver Moss gas tank door: $10
Brand new SR OEM oil pan (installed, then taken off the next day on an engine that was on an engine stand): SOLD
S14 ebrake cables: $40
s14 windshield wiper motor: $10
S14 tension rod brackets: $30
S14 SR lower intake manifold: $30
S13 Speed sensor: $50
SR Crank Angle Sensor (CAS): $50
S14 SR idle air control vavle: $30
S14 power window motors and rails: $30 each (only passenger side left)
S14 SR fuel rail with injectors: $80
KA engine to manual trans mounts: $30 each
S14 manual trans mount: $20
S14 hood hinges: $20
power steering banjos: $10 each
SR power steering pump bracket: $40
SR alternator bracket: $40
S14 hood latch: $15
power steering res: $10
Touge Factory SR hot pipe: $25
Factory cat: $20
S14 front crossmember: $40
S14 Block: $200 each
S14 SR head with valves: $200
S14 SR second oil pan: $50
SR engine to trans sandwich plate: $30
S14 SR crank: $50
SR starter: $50
GReddy Speed Limiter Cut: $40
4x6 H4 Conversion: $20
AE86 Zenki Driver side tail light: $40
SR Engine Bracket: $50 per pair
If you see something pictured that isnt listed just shoot me a price of a pm to ask and ill be happy to work with you.
thanks
adam k
Link to pictures because there are over 150....soooooo enjoy haha
garage sale pictures by knapikpb - Photobucket
not anti-drift, just pro-grip
Knapik is offline   Reply With Quote
