Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Suspension
Old 11-29-2011, 02:11 PM   #1
IMPORTIMAGE
IMPORTIMAGE's Avatar
Trader Rating: (78)
IMPORTIMAGE is an unknown quantity at this point
Feedback Score: 78 reviews
Send a message via AIM to IMPORTIMAGE
Thumbs up Fortune Auto Coilovers! 500 Series and Dreadnaught series! FREE SHIPPING @ IIR!*****
CALL 239-540-6385 OR 804-690-2452 and mention BILLY to receive special pricing ON ZILVIA!!!!!
**COILOVERS NOW HAVE A BLACK COATING TO PREVENT RUST**
Zilvia, We are now the Master Dealers of Fortune Auto coilovers!
**Join their Facebook page!** Fortune Auto's Facebook Page
Fortune Auto | Facebook
All coilovers incorporate a 50mm piston, 30 way damping, fully anodized body, custom rates & a 1 year warranty. This rigorous testing has earned us our ISO certification. Furthermore we incorporate features only found on our coilovers such as Seamless stainless steel monotubes, Forged lower mounts & proprietary nitrogen gas chambers.
Features:
* Dyno tested***
* Stainless steel body / piston
* 30-way adjustable dampers
* Pillowball mounts
* Forged aluminum locking collars
* Dust boots on all pistons
* 50mm piston (beyond the industry standard of 44-47mm)
* Anodized aluminum camber plates** on front upper-mounts
* Fully anodized body
* 1 year Manufacturer's Warranty
* Height adjustment independent of preload
* ISO 9002 certification
Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned us our ISO certification.
THEY GO LOW!
ALL FORTUNE AUTO COILOVERS CAN BE UPGRADED WITH SWIFT SPRINGS FROM THE FACTORY!! HELPER SPRINGS ALSO AVAILABLE!
Add $375 for Swift Springs!
OR
Add $475 for Swift springs with Fortune rear helper springs!
Add $500 for Swift springs with Swift rear helper springs!
Spring Upgrade? Why Swift Springs?
Swift springs of Japan noticed that most spring manufacturers use old silicone chrome material, which is not strong enough for automotive springs. Other manufacturers use a heat tempering method that damaged the strength of the material that inevitably require more coils, in turn, more weight.
The material was also suffering from a shortened life span. With springs like this leading the industry, Swift saw massive room for improvement.
Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, Swift could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke.
Helper Assist Springs:
Assist springs have two functions. The first is the spring adds a progressive rate to the initial portion of the stroke. This progression can add increased comfort is used on a daily driver coilover setup that has stiff springs installed. It provides racers added softer spring rate progression. Once the assist crushes, the normal spring rate will take over.
The second job is the same as helper springs. They prevent the loss of traction during rebound, and extreme cornering.
Assist springs are designed to repeatedly be fully crushed. Every assist spring crushes to the same height. That allows drivers to change assist springs without resetting the spring perch on coilover without changing ride height.
ALSO INQUIRE ABOUT OUR DRAG SPEC OPTION!!
CUSTOM RATES AND VALVING AVAILABLE FREE OF CHARGE!
Multiple Time Attack Winning Fortune Auto Evos!
Introducing the NEW Fortune Auto Dreadnaught series!
Fortune Auto Dreadnought Series features:
Street-able track suspension
Inverted Mono-Tube damper with high pressure nitrogen housing
Swift springs standard
Helper springs standard
Titanium fasteners standard
Dyno tested
Rebuild-able
Revalve-able
Assembled in the USA
Dyno tested
Oversized digressive 50mm piston
Italian IP synthetic shock oil
Compression adjustable
Forged Aluminum mounts and top hats
Height adjustment independent of pre-load
1 year warranty
Applications:
Evo 8
Evo 9
Evo X
S13
S14
S15
E36
E46
S197 Mustang
EP3 Civic
FC RX7
B15 Sentra
Porsche 996
Subaru GC8 (all years WRX & STI)
Subaru GDB (all years WRX & STI)
Subaru GDF (all years WRX & STI)
Toyota Yaris
IMPORTIMAGE is offline
Old 11-29-2011, 06:33 PM   #2
S13ZX
S13ZX is an unknown quantity at this point
price on street/track coilover for an s13?
S13ZX is offline
Old 11-30-2011, 10:07 AM   #3
davinci
davinci is an unknown quantity at this point
i would like to know as well
davinci is offline
Old 12-01-2011, 01:05 PM   #4
IMPORTIMAGE
Trader Rating: (78)
Thursday Bump!
Regards,
[email protected]
AIM: ImportImageBilly
www.importimageracing.com
Shop Line: 239-540-6385
Direct Line: 804-690-2452
Visa/Mastercard/Discover/Paypal and (amex) Google checkout!
Import Image Racing - Automobiles and Parts - Cape Coral | Facebook
Old 12-02-2011, 08:34 AM   #5
IMPORTIMAGE
Trader Rating: (78)
It's finally Friday!
Regards,
[email protected]
Old 12-03-2011, 06:57 PM   #6
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
price on all coilover series for s13 shipped to 96367 please.
Luvs2slide is offline
Old 12-03-2011, 07:53 PM   #7
STL240SXDRIFT
STL240SXDRIFT's Avatar
STL240SXDRIFT is an unknown quantity at this point
Price for both seperately to 63304
STL240SXDRIFT is offline
Old 12-04-2011, 03:17 AM   #8
SupaDoopa
SupaDoopa's Avatar
Trader Rating: (26)
Feedback Score: 26 reviews
Pricing on both to 02711 for S13.
SupaDoopa is offline
Old 12-04-2011, 10:15 PM   #9
isaias650
isaias650 is an unknown quantity at this point
how much for s14 98 to shipped to 94014?
isaias650 is offline
Old 12-05-2011, 08:42 AM   #10
IMPORTIMAGE
Trader Rating: (78)
Everyone has PM!
Happy Monday!
Get the week started off with some new parts!
Regards,
[email protected]
Old 12-06-2011, 08:16 AM   #11
IMPORTIMAGE
Trader Rating: (78)
Need a quote? No problem, let us know what you need!
Regards,
[email protected]
Old 12-06-2011, 05:45 PM   #12
DH1991
DH1991 is an unknown quantity at this point
Quote 500 series for S14 to 19975 please.
DH1991 is offline
Old 12-08-2011, 07:23 AM   #13
IMPORTIMAGE
Trader Rating: (78)
Need a quote? We've got you covered!
Let us know what you need
Regards,
[email protected]
Old 12-09-2011, 01:59 PM   #14
IMPORTIMAGE
Trader Rating: (78)
Weekends almost here!
Regards,
[email protected]
Old 12-12-2011, 08:14 PM   #15
pnoyryder
pnoyryder is an unknown quantity at this point
Price for both seperately for s14 shipped to 94566
pnoyryder is offline
Old 12-13-2011, 09:08 AM   #16
IMPORTIMAGE
Trader Rating: (78)
Tuesday bump!
Regards,
[email protected]
Old 12-13-2011, 04:59 PM   #17
.emerson.
.emerson. is an unknown quantity at this point
Quote for Nissan S14 to 93454 please.
Where in California do I get these rebuilt?
.emerson. is offline
Old 12-15-2011, 07:43 PM   #18
Project S13
Project S13 is an unknown quantity at this point
Price for 500 series shipped to 89101. Also were in las Vegas nv can I get them rebuilt ?
Project S13 is offline
Old 12-19-2011, 07:38 AM   #19
IMPORTIMAGE
Trader Rating: (78)
Happy Holidays!
Regards,
[email protected]
Old 12-20-2011, 11:13 AM   #20
IMPORTIMAGE
Trader Rating: (78)
Tuesday bump!
So close to Christmas!
Regards,
[email protected]
Old 12-21-2011, 03:15 PM   #21
IMPORTIMAGE
Trader Rating: (78)
We hope everyone has safe travels home for the holidays!
Regards,
[email protected]
Old 12-21-2011, 03:51 PM   #22
North
North is an unknown quantity at this point
What spring rates are available for the 500 Series with 6" Swift springs? I want something around 6/5 front/rear. Also, a price for the above shipped to 09464.
North is offline
Old 12-22-2011, 12:25 PM   #23
IMPORTIMAGE
Trader Rating: (78)
Need last minute gifts? We've got you covered!
Regards,
[email protected]
Old 12-23-2011, 08:15 AM   #24
IMPORTIMAGE
Trader Rating: (78)
Friday before Christmas!
Regards,
[email protected]
ImportImageRacing | Discount Performance Parts | Subaru, Mitsubishi, Nissan, Mazda Import Image Racing
Old 12-24-2011, 10:50 AM   #25
flatout
flatout's Avatar
flatout is an unknown quantity at this point
price on both shipped to 32003 for s13
flatout is offline
Old 12-25-2011, 07:28 PM   #26
tamdo7114
tamdo7114 is an unknown quantity at this point
price for both shipped to 92704 for s13
tamdo7114 is offline
Old 12-27-2011, 11:31 AM   #27
IMPORTIMAGE
Trader Rating: (78)
PMED!
We hope everyone had a wonderful holiday weekend!
Regards,
[email protected]
Old 12-27-2011, 11:53 AM   #28
IMPORTIMAGE
Trader Rating: (78)
PMED!
Regards,
[email protected]
Old 12-28-2011, 12:58 PM   #29
IMPORTIMAGE
Trader Rating: (78)
Get your parts before the weekend!
Regards,
[email protected]
Old 12-28-2011, 09:12 PM   #30
Randall
Randall has a little shameless behavior in the past
price on both shipped to 37355 s14
Randall is offline
