Old 12-06-2011, 03:53 AM   #1
sandy ms6
sandy ms6's Avatar
sandy ms6 is an unknown quantity at this point
Socal white bunny 1.0, s14 wiring harness's
First up is my white bunny clutch setup I recently bought for my KA! Its has the d21 flywheel with a luk pro gold towing clutch, guy held around 350hp. Straight bolt on to any KA just have to modify the dust plate if you plan to use one. I never used it but it has some good meat still left on it. Comes with d21 flywheel, 6 pressure plate bolts, and meaty a$$ clutch disc 100$ obo or trade for a upgraded KA flywheel plus cash if needed or a clean stock one plus 40$
s14 engine wiring harness unknown year, clean, and has a couple broken clips, no cut wires though! Pictures go from ECU to the MAF, end to end... 50$ obo
s14 trans harness, A little dirty but nothing out of the usual. Im not completly sure but I think it from a 5speed. It has 2 cut wires, which is to the 2nd to last sensor, easy fix. Other than that everything is awesome. Last picture shows where it was cut. sold
Will trade for s13 parts(oem or not) or anything else universal to complete my turbo setup(ie: gauges, wastegate, heat wrap, turbo heat shell, you get the picture)
sandy ms6 is offline   Reply With Quote
Old 12-07-2011, 12:47 PM   #2
sandy ms6
sandy ms6's Avatar
BUMP! Hit me up im open for trades
Old 12-07-2011, 02:15 PM   #3
Dorifto Machine
Dorifto Machine's Avatar
Dorifto Machine is a well-known jackass
Pm Sent to you for Trans wire harness.
Dorifto Machine is offline   Reply With Quote
Old 12-09-2011, 09:23 PM   #4
sandy ms6
sandy ms6's Avatar
Last bump!
Old 12-09-2011, 10:21 PM   #5
rangerjavi
rangerjavi's Avatar
rangerjavi is an unknown quantity at this point
Bump because first white bunny clutch setup I saw for sale.
Being a Floridian is a birth right!
rangerjavi is offline   Reply With Quote
Old 12-18-2011, 02:40 PM   #6
sandy ms6
sandy ms6's Avatar
Lower harness sold everything else still available
clutch, flywheel, harness, s14, white bunny
