clutch not working after 15 minutes of driving
I have a 91 240sx and I dropped the trans and reinstalled the clutch not too long ago. First I didn't torque down the master cylinder bolts hard enouph so the clutch got magma hot then started to quit. I torqued them down and now the clutch works fine for about 15 minutes, then starts to slip. Time for a new clutch or did I do something wrong when installing the clutch?
![]() Join Date: Dec 2001
why would you take your master cyl off when switching the clutch in the first place?
*image exceeds forum limit* -Moderation |
![]() Join Date: Sep 2003
A brand new clutch is very brittle and can easily be burned out in the first few minutes of driving especially if it got magma hot. drop the tranny and make sure your disc isnt toast. The slave cylinder will not make the clutch slip because the hydraulic pressure it produces is only to pull the clutch away from the flywheel. Even if the slave had no fluid in it the clutch should grab but you wouldnt be able to shift.
Hi |
#5 |
![]() Join Date: Aug 2002
Check to make sure there is enough freeplay in the pedal. If there is little to no freeplay the clutch is slightly disengaged and slips easily. This happened to me when I got a new clutch.
Ryan |
