Old 12-08-2011, 08:56 PM   #1
wileymotorsports
wileymotorsports is an unknown quantity at this point
TPS Adjustment Help
Hello, I have a 1991 240sx with the s13 sr20det black top, yesterday I went to check my throttle position sensor voltage, because i read at idle the sensor should read .45V. I plugged the red end of my volt meter into the middle wire and the black end of the volt meter to the black wire on the sensor and the meter said .30v, I went to adjust the tps sensor and noticed that it was adjust as far down as possible and if i adjust it the other way my voltage reading goes down? Right now my car is idling at 1500rpm and I saw it should be around 895 rpms, and if I adjust the sensor the idle goes up? Another bit of info at WOT my voltage reading from the TPS only goes to 3v which in searching it should be 4v. So Im pretty confused at this time any help would be appreciated. Thank you, Kyle
wileymotorsports is offline   Reply With Quote
Old 12-09-2011, 03:36 PM   #2
sugarkouki
sugarkouki is an unknown quantity at this point
Any luck on this?
sugarkouki is offline   Reply With Quote
Old 12-09-2011, 03:48 PM   #3
wileymotorsports
no luck yet. I tested it agian last night and I got the same reading. Then I tried putting a spacer in between the TPS and throttle lever until it read correct voltage, started up my car and it idled right around 900 rpms, but the engine seemed to be cutting out slightly, Maybe a bad TPS? The car runs great, but my idles high and tps is reading incorrect, idk any help??
Old 12-09-2011, 03:56 PM   #4
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
bad tps, or you are testing the wrong wires...
Try with the negative of the multimeter on a chassis ground. See what you get.
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 12-09-2011, 04:01 PM   #5
besTint
Trader Rating: (81)
besTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the roughbesTint is a jewel in the rough
Feedback Score: 81 reviews
Send a message via AIM to besTint
did you try to clock the tps sensor? you may have the wrong tps sensor or like ^ the guy saids, it might be defective. find someone around you that will let you borrow an extra one to test. id give you one to borrow if you were local.
http://squarespokes.com/
besTint is offline   Reply With Quote
Old 12-09-2011, 04:22 PM   #6
wileymotorsports
Im thinking it might be a bad tps. I tried putting the negative end of the multimeter on a chassis ground and got the same results. I dont know anyone thatll let me borrow their sensor. Is there anyway of testing to make sure the sensor is faulty before dropping the $ on a new one? Can anyone recommened a good place to get a new one? Is this a SR20det specific sensor?
Old 12-09-2011, 04:31 PM   #7
besTint
Trader Rating: (81)
Genuine OEM Nissan TPS (Throttle Position Sensor) Sensor SR20DET S13
they usually have it in stock. if you decide to buy a used one, i have a couple for sale. $50 shipped
http://zilvia.net/f/sale-items/41651...0sx-parts.html
#32 with stock SR throttle body.
all are tested and in good working order.
Old 12-09-2011, 04:39 PM   #8
wileymotorsports
Thanks for everyones help, im gonna mess with the sensor tonight to make 100% sure I am testing it properly. Ill probably end up ordering a new one. Is it ok to drive the car in the mean time?
