Old 12-23-2011, 04:41 PM   #1
Couped_up'd
Couped_up'd's Avatar
Trader Rating: (47)
Couped_up'd is an unknown quantity at this point
Feedback Score: 47 reviews
Updated Partout 1990 Nissan 240sx Hurry BEFORE SCRAPED!
1990 Nissan 240sx Part Out
Information:
Parting out a 1990 Nissan 240sx, because of the bent valve on cylinder number 4. Nothing else is wrong with the car. Expect some items to have the normal wear, although, this car has been well kept. Items are good for there age. Please see further details to get more info on each item! I am located in OKLAHOMA CITY, I will ship at your cost.
Engine:
5-Speed Convertion SOLD!
PARTS Left Overs List!
- 5 Speed Swap Trans Bolts $15.00
- 5 Speed Clutch and flywheel bolts $15.00
- 5 Speed Clutch and Flywheel $40.00
- 5 Speed Trans $50.00 Pick up Only.
Pictures:N/A Sold
SOHC Fan Shroud
-Used has a broken tab.
Asking $10.00
SOHC MAF with out pigtail.
-Used, still works. =) (Can use on sr20?)
Asking $20.00
Ka24 Radiator
-BRAND NEW! Still have receipt!
Asking $30.00
Ka24e Sohc Power Steering Pump
-Used, no leaks. Pump and hose included. Along with bolts, and belt.
Asking $20.00
Ka24e Sohc Distributor & plug wires
-BRAND NEW, still have reciept! Will include the brand new plug wires as well. It has a new cap and rotor too!
Asking $20.00
Non-ABS Brake Booster
-Used, and works. Good for you turbo guys!
Asking $20.00
Non-ABS Brake master Cylinder
-Works fine, used.
Asking $10.00
Ka24e SOHC Engine Wire Harness
-Used, and has signs of "repair" Looks to only be the injector pigtails where changed out. GOOD and works! Would do GREAT for a conversion harness.
Asking $34.00 PRICE DROP
COMPLETE A/c System
Details: Includes anything, and everything. STILL WORKS IN THE CAR NOW! So no worry about if it worked or not. Includes everything...
includes:
-Compressor
-Compressor lines
-Hard lines
-Condenser
-Condenser lines
-EVEN the climate control!
Asking $50.00
Interior
Drive Side MIRROR $15.00!
passenger & Driver Door Panels
-Used, very good shape. One has the "de-fabric mod" already done. No cracks I can see, no horiable wear.
Asking $40.00 or $20each
Sunroof Latch
-Works
Asking $12.00
Rear Black Trim Panels
-Good shape, black in color
Asking 20each!
BLACK CARPET SOLD SOLDD!
-Good shape, very rare! Alittle dirty...Alittle worn. Not bad at all.
Asking $SOLD
Center Console
-Used, black in color, comes with switches!
Asking $15.00
Cluster Trim / Clutster / Buttons / Steering wheel
lol.
Cluster has a speed o problem. Asking $5.00
Hazard buttons, all 4. $10.00
Cluster Trim around cluster $10.00
Steering wheel $10.00
Wiper Switch $10.00
Turn Switch $10.00
COMPLETE LOCKS! WITH KEY! OG KEYS AT THAT!
Driver lock, Passenger lock, both with handles. Steering column Key tumbler, rear lock insert, and 2 keys $60.00
Exterior
Reflectors Orange
-Slight over spray, I will remove the over spray for free.
Asking BOTH $10.00
Reflectors Red
-Slight over spray, I will remove the over spray free.
Asking $10.00 BOTH
Dohc Bumper lights
-over spray, I will remove the over spray when purchased. Comes with bulbs, and hardwire.
Asking 20.00
Aftermarket/other cool stuffz
Innovate Wide Band o2
-Kit is for tuning only, no gauge. Works Fine. LC-1. You can hook a gauge up to it i believe.
Asking 90.00
OEM 5 Lug Conversion
-Used, alittle surface rust, All threads are ok! Screws a lug nut on each. 100% bolt on to your S13! (S13 knuckles)
Comes with:
Front Hubs (j30 conversion)
NEW bearings in front
S14 Rear hubs
S14 Front ROTORS
S14 Rear ROTORS
S13 Front and Rear Calipers (if you need them)
Asking $300.00
ANOTHER 5lug Convertion
-Used, good usable shape. This kit only includes the HUBS
Front Hubs (believe to be s14, or S13 Conversions)
300zx Rear hubs
Asking $180.00
Sr20det Downpipe Ellbow
-Used works fine, has 2 studs missing, YOU CAN use a nut and bolt!
Asking $25.00
HKS knock off BOV
-Used, works fine. Has a nipple broke off. I will include the plastic piece I was using to make it work. INCLUDES FLANGE!!
Asking $30.00
S14 Sr20det TO S13 Wire Harness
-Needs work. Had a power fc hooked up, we cut the power fc wires out. Other then that, should work after a good look over.
Asking $SOLD
ANYTHING ELSE!!! THIS CAR IS GOING TO BE SCRAPED!
Couped_up'd is offline   Reply With Quote
