Old 12-24-2011, 01:42 AM   #1
nep
nep's Avatar
nep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the roughnep is a jewel in the rough
ka24de won't start. Getting fuel, spark
hey everyone, car refuses to start. Turns over just fine, pulled the plugs to check spark and when i did they smelled of fuel, so it appears i can cross those two off the list. i pulled the IACV and cleaned it thinking it was somehow choking the car but when i replaced it still nothing. Battery is good. Pulled the intake and cleaned the throttle body. running out of ideas. Anyone?
nep is offline   Reply With Quote
Old 12-24-2011, 02:16 AM   #2
silver350z05rb
silver350z05rb is an unknown quantity at this point
There are many of these threads here with the same issues,all recent as well, check timing, injectors could be dumping too much fuel and choking the engine and wearing out your rings which lower your compression,google, Zilvia search
silver350z05rb is offline   Reply With Quote
Old 12-24-2011, 07:45 AM   #3
redline racer510
redline racer510's Avatar
redline racer510 is on the path to ruinredline racer510 is on the path to ruin
First check your timing chain to make sure you haven't skipped a linkand also that your timing is correct. Next thing you should do is remove your fuel rail and see if your injector seals are damaged by having someone crank your engine while you look for injectors that have fuel leaking past the seals which may be causing your engine to flood with fuel, give us an update after checking these two things.
WARNING: User has a low tolerance for stupidity. Post at your own risk.
redline racer510 is offline   Reply With Quote
Old 12-24-2011, 07:39 PM   #4
nep
nep's Avatar
Thanks to you both, i will check my timing and injector seals tomorrow and report back.
Old 12-25-2011, 05:02 PM   #5
clutch187
clutch187 is an unknown quantity at this point
coolant temp
check to see if coolant temp sensor is hooked up or that it doesnt have any broken wires. i bought my 240 from a guy who couldnt get it to start and that was the problem
clutch187 is offline   Reply With Quote
