Old 01-01-2012, 10:20 PM   #1
freeagent3117
freeagent3117's Avatar
freeagent3117 is an unknown quantity at this point
Water temp gauge install help WITH PICS!!!!!
Ok so where do these wires go? Why is there two sets of grounds and 12v wires? And does the sender wire go straight from the sensor to gauge??? Thanks!!!!
p.s. just click on the pic to magnify it. Dont make fun of my paint skills!!!!
freeagent3117 is offline   Reply With Quote
Old 01-01-2012, 10:30 PM   #2
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
The "switched" wire is goes to something that will turn on with your engine and turn off with your engine. So the ignition wire is where you'd splice it into. The other power is a constant power wire, so look for a wire that has constant 12V source at all times. One of the grounds you are talking about is probably a power wire for the backlight of the gauge. Find a wire that turns on with your headlights or running lights. If there is no backlight, then simply ground the wires it tells you to.
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 01-01-2012, 10:36 PM   #3
freeagent3117
It does have a backlight but i thinks its on all the time. So two grounds? It just seems odd but whatever ill try it. The sensor wire is correct though? Im just gonna run a 18gauge wire from the little adapter thingy in the radiator hose. (with the sensor in it) Just wondering, why does a gauge need a constant? Thanks Bud!!!
Old 01-01-2012, 10:43 PM   #4
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
1 wire from sensor to gauge (s). Ignition (I) goes to something that turns on the gauges. I wired mine with 2 toggle switch one to turn on the lights and one to turn on the actual gauge to function. (g) ground goes to ground lol and u good to go. Don't do constant power, because even when your car is off the gauge Is still on, u don't want that
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 01-01-2012, 10:50 PM   #5
Michaelwinne
Michaelwinne's Avatar
Michaelwinne is an unknown quantity at this point
I'm digging the paint skillz
Michaelwinne is offline   Reply With Quote
Old 01-01-2012, 10:51 PM   #6
freeagent3117
So can both grounds...ground got it lol. and both 12v can be run together to a switched 12v? i would just test it but sr20 comes on the 3rd!!!!mm
Old 01-01-2012, 10:56 PM   #7
godrifttoday
Trader Rating: (82)
here ya go.. Personally I don't like my gauge lights on at all times if u do then disregard one switch.
Some people simply tap into the stock headlight swich wiring. but i dont
[ IMG]http://i41.tinypic.com/30sxatu.jpg[/IMG]
Old 01-01-2012, 11:02 PM   #8
freeagent3117
here ya go
Thanks, now my paint skills look a lot better!!!
Old 01-01-2012, 11:08 PM   #9
godrifttoday
Trader Rating: (82)
No problem
Old 02-25-2012, 08:06 PM   #10
Michaelwinne
Wow I was googling something and it brought me to this lol
